'67 Belvedere Steering Column Rebuild #2176250
10/16/16 07:08 PM
10/16/16 07:08 PM
People's Republic of Mass.
Belvedere2 Offline OP
I'm wondering where to send my steering column in for a rebuild or if I can do it myself. I have that wonderful dead spot in my steering. I've replaced the steering box; Firm Feel, and everything forward of it and still have the dead spot. Power steering converted to manual so its even more annoying now. Are there gears that need replacing in the column itself? Thanks!
Re: '67 Belvedere Steering Column Rebuild [Re: Belvedere2] #2176373
10/16/16 09:19 PM
10/16/16 09:19 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
No gears in there, one piece bearing on top, and the lower bearing will fall apart when taking the shaft out. Balls will come out of the races. Unsure who rebuilds them.
Re: '67 Belvedere Steering Column Rebuild [Re: Belvedere2] #2176722
10/17/16 10:37 AM
10/17/16 10:37 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Only thing in there will cause in kind of dead spot is looseness in the lower coupler.
Or worst case ( it would have to be pretty bad ) is wear between the 2 sections of the main shaft itself.( never seen that though)
Like said ,,, the lower bearing on a 67 is a weird animal and can be a little complicated to a novice. Its a one year only deal
I can do it if your not comfortable doing so . I have a 68 Column on the bench now actually.
Re: '67 Belvedere Steering Column Rebuild [Re: gtx6970] #2176765
10/17/16 11:58 AM
10/17/16 11:58 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Indeed, an unobtainable part... Had to have a machine shop manufacture the plastic piece, that holds the metal retainer ( where the ball bearings fit into) . Purchased a package of new ball bearings also at a bearing supply house...
Re: '67 Belvedere Steering Column Rebuild [Re: gtx6970] #2177137
10/17/16 07:15 PM
10/17/16 07:15 PM
Thank you. You can PM me what I'd need to do to get the part/column to you. Cost etc.
Re: '67 Belvedere Steering Column Rebuild [Re: Belvedere2] #2177304
10/17/16 10:46 PM
10/17/16 10:46 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Will send a pm sometime tomorrow
Re: '67 Belvedere Steering Column Rebuild [Re: Belvedere2] #2180277
10/22/16 12:58 PM
10/22/16 12:58 PM
Okla
dpatt67 Offline
dpatt67  Offline
Okla
SMSmopar.com rebuilds columns
66 Coronet
67 Satellite
15 Ram 3500
12 Challenger R/T
Re: '67 Belvedere Steering Column Rebuild [Re: minivan] #2184959
10/28/16 11:06 PM
10/28/16 11:06 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
There is a fellow making the lower bearing kit for a 67. I bought one in case I ever need it for my cars.
Re: '67 Belvedere Steering Column Rebuild [Re: markz528] #2184976
10/28/16 11:22 PM
10/28/16 11:22 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Good to know.. Do you have a website or name??
Re: '67 Belvedere Steering Column Rebuild [Re: minivan] #2184986
10/28/16 11:34 PM
10/28/16 11:34 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
http://dynamicrenovation.net/viewitem.php?productid=90
Re: '67 Belvedere Steering Column Rebuild [Re: Belvedere2] #2185386
10/29/16 05:00 PM
10/29/16 05:00 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
TY, that is good info on a very hard part to find.....
