how to remove wipers from outside #2176756
10/17/16 11:46 AM
10/17/16 11:46 AM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
69 b body.
Re: how to remove wipers from outside [Re: moparpro] #2176827
10/17/16 01:12 PM
10/17/16 01:12 PM
crlush Offline
crlush  Offline
There's a clip on the wiper where it attaches to the spline on the cowl, if it's your first time you might want to put some masking tape or something around the area so if you slip you don't mess up the paint. I just use something to move the clip (small screwdriver) and pull up a bit till you can see that the clip is over the splines then grab both sides of the wiper (right where it attaches to the splines) and pull straight up. It's easier to do on a car your getting ready to repair the because your not worried about scratching anything.
Re: how to remove wipers from outside [Re: crlush] #2177257
10/17/16 09:41 PM
10/17/16 09:41 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
thank you
Re: how to remove wipers from outside [Re: moparpro] #2177273
10/17/16 10:05 PM
10/17/16 10:05 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Get one of these, best 13 bucks you can spend.
https://store.snapon.com/Window-and-Wind...ol-P636287.aspx
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: how to remove wipers from outside [Re: 5wndwcpe] #2177340
10/17/16 11:16 PM
10/17/16 11:16 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I bought a very tool similar to this one. Works great.
