Hey guys,
Im interested in your thoughts on this one...
My setup has Wilwood Dynapros front calipers and rears are Nissan Skyline single piston alum calipers (a common swap over here)
My setup is manual brakes with an underdash / cantilever arrangement - pedal ratio is around 6.4 and the current setup does'nt give me enough bite on the rotors, so I'm thinking a 7/8" bore MC will up the ante in the line pressure dept.
The pedal is great without excessive travel and there is no air in the system as far as I can tell. MC was bench bled as well.
In the front line I have a line lock and in the rear, and adjustable proportioning valve which is backed right off for full pressure to the rears at present, but I'm not getting enough grab/bite.
I will be checking pressure at the calipers as soon as the gauge kit turns up, but in the meantime, I'm wondering which 7/8" bore MC Pt # is used. This is a 2 bolt MC deal (std Mopar 2 bolt MC spacing.
Would love some input on my setup and suggestions of a source for the MC.
Thanks !
