Can I rebuild a 46RE Transmission
#2175064
10/15/16 03:53 AM
10/15/16 03:53 AM
mld94
mld94
Doing some research, watching youtube videos has me thinking about attempting to rebuild a 46 RE transmission. If one can disassemble and assemble sb and bb mopar engines, a transmission should be within reach, right ?
I bought a 98 Dodge Ram 4x4 that only has first gear.....no reverse, will not shift out of first, and has no engine braking in first.
Can/should a novice attempt this ??
Re: Can I rebuild a 46RE Transmission
[Re: ]
#2175065
10/15/16 03:57 AM
10/15/16 03:57 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Sure..I have done it...couple 46RE ...46RH..
they are a 727 with an over drive...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: ]
#2175066
10/15/16 04:02 AM
10/15/16 04:02 AM
70AARcuda
las vegas
https://www.youtube.com/watch?v=Ta1Wunn2cdcThis video shows the rebuilding of the overdrive section...ignore that it says 904-999 . The overdrive is the same on all of them.
Tony
[Re: ]
#2175071
10/15/16 05:21 AM
10/15/16 05:21 AM
Posts: 20,190 Park Forest, IL
slantzilla
Park Forest, IL
Are you sure it's mechanical issues and not the solenoids?
[Re: Sixpak]
#2175201
10/15/16 12:42 PM
10/15/16 12:42 PM
Posts: 21,452 It's a dry heat
gtx6970
It's a dry heat
When doing a 727, for comparison, you need a dial indicator and stand to check the end play on the output shaft, some feeler gauges to check the clutch packs, and some sort of tool to compress the springs in the clutch pack to remove the friction material. I've used vise grip welding clamps, c clamps, and even my hydraulic press. Most tranny builders have a unique tool for the job. Other than that it's standard hand tools. You'll need more than that to do the OD unit. There is one heck of a spring in there that needs compressed to removed the snap rings / reaction plate. Plus you NEED the alignment tool to keep the frictions in place for reassembly. The tools can be bough reasonably.( bought mine off ebay) Or have a local shop do the OD unit by itself.
[Re: gtx6970]
#2175299
10/15/16 03:24 PM
10/15/16 03:24 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
When doing a 727, for comparison, you need a dial indicator and stand to check the end play on the output shaft, some feeler gauges to check the clutch packs, and some sort of tool to compress the springs in the clutch pack to remove the friction material. I've used vise grip welding clamps, c clamps, and even my hydraulic press. Most tranny builders have a unique tool for the job. Other than that it's standard hand tools. You'll need more than that to do the OD unit. There is one heck of a spring in there that needs compressed to removed the snap rings / reaction plate. Plus you NEED the alignment tool to keep the frictions in place for reassembly. The tools can be bough reasonably.( bought mine off ebay) Or have a local shop do the OD unit by itself. The Overdrive requires a special compressor tool, and an alignment shaft in addition to the tools normally needed for a 727.
[Re: UCUDANT]
#2175329
10/15/16 05:08 PM
10/15/16 05:08 PM
Posts: 198 Stinnett, Tx
rumblebee4232
Stinnett, Tx
You have to leave the tool in the overdrive until you are ready to install it, one little oops and it can misalign the components and you have to go back to the press and disassemble and start over. If I can do it anyone can Guess I got lucky when I did mine I just aligned everything by eye, didn't know you were supposed to have special tools..Did two of them that way due to hitting the transfercase on rocks and breaking the mounting flange off the OD housing..
[Re: rumblebee4232]
#2175497
10/15/16 09:58 PM
10/15/16 09:58 PM
Posts: 8,145 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
The factory manual warned me to leave the tool in. I did find that with my specific handling of that said part they were correct during an OD install. I just bumped it too.
[Re: ]
#2175639
10/16/16 01:40 AM
10/16/16 01:40 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
One thing I found out over the years is that many and I mean even techs can watch and learn how to disassemble and reassemble transmissions and do it pretty good. But many never did learn just how they work and how to diagnose a problem as in my eyes thats the harder part and what makes a good trans person and thats understanding just how they actually work and it makes it so you can diagnose trans problems without having to follow a book. But what you want to do I have seen alot of guys do as the 727 is not to hard to learn how to mechanically take apart and put back together. Its nice help if you have a friend or someone with you thats done one before just in case you need a little help. Its always nice to have someone around who has done one at least once before. I agree with some on here that you may want to just have a trans shop go through the O/D unit. I had access to the special tools like the alignment shaft which I did not take out until I was ready to install the O/D unit and the tool and press to compress the large spring for the direct clutches. There is also a few special tools for measuring what size shims go in the overdrive unit as many just use over whats in it and get away with it but if you change any hard parts in the O/D it can change what size shims it needs. Good luck with it and remember there is plenty of people on here who will help you if you have any problems. Thats the nice thing about Moparts and that is that most on here are always willing to help a fellow car person. Ron
[Re: 383man]
#2175694
10/16/16 04:41 AM
10/16/16 04:41 AM
RapidRobert
right off the bat I would (1) clean the outside case surgically clean and (2) what sixpac said, with it horizontle, measure the input shaft end play with a dial indicator & write that dimention on the inside of the bell with a sharpie for future reference when going back together
[Re: ]
#2176818
10/17/16 01:01 PM
10/17/16 01:01 PM
Posts: 1,322 Michigan
crlush
You can buy a press for cheap at harbor freight (I got mine for $150) the press tool you can make with some scrap steel (that's what I did) or buy for $80. I used my shaft to line it up. I already have a dial indicator but you can get them for really cheap as well.the money saved getting the tools you need will make up for paying someone else to do it, and then some on the first job. and will help figuring out the mystery of how they work. I bought a good manual and spent a good amount of time rebuilding my 48re but when done it worked perfectly, so if you have successfully rebuilt engines you should have no problems with a transmission.
[Re: ]
#2177501
10/18/16 03:54 AM
10/18/16 03:54 AM
70AARcuda
las vegas
I search ebay for a couple of weeks and was lucky to find someone selling the tools. I have used them a quite a few times so they have paid for themselves given what a trans shop wants to rebuild the 46RE or 46rh.
Tony
[Re: crlush]
#2177538
10/18/16 10:22 AM
10/18/16 10:22 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
You can buy a press for cheap at harbor freight (I got mine for $150) the press tool you can make with some scrap steel (that's what I did) or buy for $80. I used my shaft to line it up. I already have a dial indicator but you can get them for really cheap as well.the money saved getting the tools you need will make up for paying someone else to do it, and then some on the first job. and will help figuring out the mystery of how they work. I bought a good manual and spent a good amount of time rebuilding my 48re but when done it worked perfectly, so if you have successfully rebuilt engines you should have no problems with a transmission. where did you get your manual?
