Leak Down Tester Suggestions #2174607
10/14/16 03:56 PM
10/14/16 03:56 PM
SE Wisconsin, USA
RP's R/T's Offline OP
SE Wisconsin, USA
I am looking for a good Leak Down Tester.
Various brands out there with prices ranging from $30 to $200.
Harbor Freight to Snap On.
Single gauge to dual gauge.
For the non-professional, what would you suggest?
There is a $77-ish version with Summit that seemed good.
Re: Leak Down Tester Suggestions [Re: RP's R/T's] #2174632
10/14/16 04:15 PM
10/14/16 04:15 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I used to sell one (along with other such tools); a buddy of mine makes them and sells them through Summit & Jeg's. I think the Jeg's # is 555-80520.
Retail was about $75.
These had 2 gauges. With input set @ 100PSI, it's easy to calculate %. It's a good product, every one pre-tested/calibrated.
Re: Leak Down Tester Suggestions [Re: RP's R/T's] #2174635
10/14/16 04:21 PM
10/14/16 04:21 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Since I am not working on a pro stock I just made one. Bought a nice gauge and some pipe fittings and used part of my compression tester to plug into the cylinder. Works great and very cheap.
68 Barracuda Formula S 340
Re: Leak Down Tester Suggestions [Re: RP's R/T's] #2174664
10/14/16 04:59 PM
10/14/16 04:59 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Do yourself a favor and get a two gauge tester....FWIW I have had great service from my OTC leakdown tester for years.
Re: Leak Down Tester Suggestions [Re: RP's R/T's] #2174678
10/14/16 05:16 PM
10/14/16 05:16 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Mine is from Matco tools. It's a quality piece that has worked very well over the years.
Nautilus Racing-
Re: Leak Down Tester Suggestions [Re: Bad340fish] #2174728
10/14/16 06:27 PM
10/14/16 06:27 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The good testers have a correctly-configured orifice, pretty hard to duplicate at home since the orifice size and approach angle are critical.
Re: Leak Down Tester Suggestions [Re: RP's R/T's] #2174746
10/14/16 06:46 PM
10/14/16 06:46 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Interesting, I will have to compare it to a real tester and see how it does. I have mainly used it to compare cylinder to cylinder numbers which I think this one works OK for. I need to check leak down on the new engine and I will compare it to an actual tester. Thanks for the info.
Re: Leak Down Tester Suggestions [Re: Bad340fish] #2174775
10/14/16 07:53 PM
10/14/16 07:53 PM
I bought a older Moroso single gauge unit years ago, I still have it but the needle started sticking so I bought a better two gauge unit when I owned a airplane that was FAA approved from Aircrafts Spruce scope Chief Aircraft supply in Grants
pass, OR supply also sells them scope
Buy a good one now, not later work Good tools should last forever, if taken care of shruggy
Re: Leak Down Tester Suggestions [Re: RP's R/T's] #2174809
10/14/16 08:57 PM
10/14/16 08:57 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I have an OTC #5609, very good and not to expensive.
Mopar to the bone!!!
Re: Leak Down Tester Suggestions [Re: RP's R/T's] #2174884
10/14/16 10:40 PM
10/14/16 10:40 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
I have found on my 440 equipped E Body with TTI headers that I can only use a leak down tester or compression gauge on about 4 cylinders. I have both screw in adapters and rubber tipped adapters and several different high quality such tools from a variety of vendors. .
What tools have others found that can access all cylinders short of removing headers or pulling engine?
Re: Leak Down Tester Suggestions [Re: RP's R/T's] #2174930
10/14/16 11:36 PM
10/14/16 11:36 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
HF one is limited to 15psi. In my opinion that's not enough.
I bought one, removed the first gauge which max was 15psi, plugged it.
Set the regulator to 100psi, and hook it up. Every psi is a %.
Works great.
Re: Leak Down Tester Suggestions [Re: RP's R/T's] #2174980
10/15/16 01:15 AM
10/15/16 01:15 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Old Moroso single gauge unit for me. I've had it for years.
Re: Leak Down Tester Suggestions [Re: RP's R/T's] #2175042
10/15/16 02:47 AM
10/15/16 02:47 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I bought a 2 gauge summit with a built in adjustible regulator about 20 years ago. It has always worked fine.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Leak Down Tester Suggestions [Re: RP's R/T's] #2175057
10/15/16 03:38 AM
10/15/16 03:38 AM
I think the standard recommended by Moroso, SAE and the aircraft industry is to set the input pressure to 80 lbs and then do the math off of the pressure drop to each cylinder, IE 80/78=2.5% shruggy
Don't forget to make sure the gauge you buy and use has the metered orifice to keep it accurate scope
Re: Leak Down Tester Suggestions [Re: Cab_Burge] #2175298
10/15/16 03:22 PM
10/15/16 03:22 PM
Rio Linda, CA
Rio Linda, CA
"In the United States, FAA specifications state that engines up to 1,000 cu in displacement require an 0.040" orifice diameter, 0.250" long, 60-degree approach angle. The input pressure is set for 80 psi, and 60 psi minimum cylinder pressure is the accepted standard."
A lot of automotive testers use 100 psi so the psi numbers represent the percentage...no math required.
Re: Leak Down Tester Suggestions [Re: RP's R/T's] #2175352
10/15/16 06:00 PM
10/15/16 06:00 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Try one from ATS ( aircraft tool supply) They are certified, and can be recalibrated when needed.
Re: Leak Down Tester Suggestions [Re: RP's R/T's] #2175384
10/15/16 06:56 PM
10/15/16 06:56 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Theres nothing wrong with having high quality tools. But not real nescessary in this aplication though. We don't need to prove to the FAA that our engines are good enough to power an airplane through the sky. We just need to know if the valves or the Rings or the head gaskets are leaking. I use 100 PSI in my low cost Summit tester and it tells me what I need to know.
Re: Leak Down Tester Suggestions [Re: Hemi_Joel] #2175482
10/15/16 09:37 PM
10/15/16 09:37 PM
I think the FAA will accept up to 60% leakage and still let you operate the airplane with the proper sign offs shock
The procedure is different also on aircraft leak down test, you don't test it at TDC, you pull the piston up being tested with the prop to about 120 to 90 degrees BTDC on the compression stroke and have someone read the gauge while holding the prop at that spot work
Sometines I will pull a piston up on one of my motors until the valves close to see what the bottom ring sealing looks like thumbs
Re: Leak Down Tester Suggestions [Re: Cab_Burge] #2175504
10/15/16 10:27 PM
10/15/16 10:27 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
No, we test airplanes at TDC for leak down. The timing is a set thing at what ever degree the engine operates at for testing.
Re: Leak Down Tester Suggestions [Re: 71birdJ68] #2175542
10/15/16 11:08 PM
10/15/16 11:08 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
OTC here. works great and not too spendy
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
