Re: Are Caltrac's noisy on a street car?
[Re: crash520]
#2173987
10/13/16 08:30 PM
10/13/16 08:30 PM
Posts: 2,866 Pattison Texas
CSK
Pattison Texas
very little noise from the caltracs, but the sliders are noisy when hitting a pretty good bump.
[Re: crash520]
#2174126
10/13/16 10:51 PM
10/13/16 10:51 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Been running mine on the street for a few years. Nothing that I've ever considered worrisome. I can sort of tell when they release from the spring and then land again sometimes, but I drive pretty careful so that doesn't happen too often. Even then it's just a bit of a clunk. The biggest thing is the aluminum spring bushing. If you run that, which I do, you get more noise and "feel" transmitted into the car.
At some point you have to decide if you want a nice street musclecar, or a street/strip car. I personally embrace the racecar feel on the street. If I wanted a smooth ride, I'd jump in my Altima.
[Re: crash520]
#2174560
10/14/16 03:02 PM
10/14/16 03:02 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
The noise is of little concern compared to how harsh they are on the open road. Anything more than an inch and a half or so of travel and they are nothing short of brutal on a bumpy road at highway speed. I sold mine after my head hit the ceiling a few times and almost hurt my back on our local highways.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2174813
10/14/16 09:05 PM
10/14/16 09:05 PM
Posts: 2,414 St. Croix, US Virgin Islands
David_in_St_Croi
The noise is of little concern compared to how harsh they are on the open road. Anything more than an inch and a half or so of travel and they are nothing short of brutal on a bumpy road at highway speed. I sold mine after my head hit the ceiling a few times and almost hurt my back on our local highways. Interesting. I thought they only came into play if you were accelerating and the axle was trying to wind up as opposed to just vertical motion. Another question to throw out there on the Caltrac front: Are many people having issues with ground clearance problems with the Caltracs?
[Re: jbc426]
#2174923
10/14/16 11:29 PM
10/14/16 11:29 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
The noise is of little concern compared to how harsh they are on the open road. Anything more than an inch and a half or so of travel and they are nothing short of brutal on a bumpy road at highway speed. I sold mine after my head hit the ceiling a few times and almost hurt my back on our local highways. I agree they make the car a little rigid but my Barracuda is low so it needs to be, still would not remove them, they do there job.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: StealthWedge67]
#2174993
10/15/16 01:36 AM
10/15/16 01:36 AM
StealthWedge67
Puyallup, WA
They're not even really close to being a clearance issue. I can't imagine them hitting anything.
[Re: Mr.Yuck]
#2175206
10/15/16 12:47 PM
10/15/16 12:47 PM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
My dad has them on his Challenger, noise and ride on the street are not bad. Ground clearance is a problem though, But I think he has the longer front plates.
The only Carbs I care about are under the hood!
[Re: crash520]
#2175267
10/15/16 02:16 PM
10/15/16 02:16 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
Guys, those running Caltrac's on their street car, do that rattle/thump and bang during normal cruising?? The squeak is from the front eye bushings. Grease them once a year. I wish there were grease fittings. The rattles and banging is from the bolt on top of the spring. I had a piece of heater hose over the bolt for several years. It worked but wore out quickly. Now I have a 1/4" thick piece of polyurethane glued to the top of the spring. It is holding up much better than the heater hose. Now if I could just silence my worn out strut rod bushings without tearing apart the whole front end i'd be happy. They make way more noise than the caltracs.
[Re: carhunter]
#2175399
10/15/16 07:28 PM
10/15/16 07:28 PM
Posts: 8,299 fredericksburg,va
cudaman1969
fredericksburg,va
Mine also are low ,they will bottom out if I go to fast backing out of my driveway and my driveway is not steep. You must have a three inch spacer between the housing perch and spring or some really short tires,
[Re: carhunter]
#2175881
10/16/16 10:55 AM
10/16/16 10:55 AM
cudaman1969
fredericksburg,va
Tires are 275-50-15 I'm about to put 275-60-15 on. The caltrac's are 3 1/2 in. from ground not much clearance.I just have to deal with it. I was thinking at the wheel not the front, duh on my part.
