Re: BB Oil Pumps
[Re: 408strokerdart]
#2171036
10/09/16 07:22 PM
10/09/16 07:22 PM
dartman366
Mt. Vernon, Ohio
What is the best set up going right now for wet sump? I have a single line Indy billet cover already. Is the billet Milodon pump good or is everyone using something different? The Milodon billet is what I have put on my new 512 along with the Milodon billet cover, heard alot of good about this set-up, I know it's a nice piece, won't know anything more about it untill spring when we fire it up and make some passes.
Re: BB Oil Pumps
#2171080
10/09/16 08:49 PM
10/09/16 08:49 PM
Posts: 43,233 Bend,OR USA
Cab_Burge
Re: BB Oil Pumps
#2171100
10/09/16 09:03 PM
10/09/16 09:03 PM
crabman173
crabman173
The reason Indy made a pick up is it has the square in / volume capacity to actually support a dual line--It is known by many that the original Milodon pick up was too small to be more effective with dual lines--all that being said I have never seen any mopar engine that could not live long happy life with a single line external set up. Big Note if you use that Indy cover!!! If you over tighten it --that thing eats a big noodle first turn and you are screwed--call Indy they ask what did you Torque it at--you say whatever number and they respond should have been 5 ft lbs--tell them you did it to 5 Ft Lbs and they say just snug etc If you use one--put some red Loctite on the bolts and I say just a TAD over finger tight with a short wrench--they are trouble --I do NOT use them--The newest Milodon is a better piece IMO I say a single line cover on a stock iron pump is a really great set up or...use the Milodon pump with the good rotors--it is a top shelf unit Never ever over tighten and ALWAYS use a priming shaft to test spin after you install--You will see that with either of these units it will lock down when over tightened and that ain't much I promise! The Indy pick up is one piece they got right, maybe the only one.
Re: BB Oil Pumps
#2172361
10/11/16 07:28 PM
10/11/16 07:28 PM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I'm going to add a steel shim wear plate to that system to cut down on the wear. I can't believe its taken this long for someone to realize the necessity of this part !!!
Re: BB Oil Pumps
#2172470
10/11/16 09:42 PM
10/11/16 09:42 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
IMO Charlie Wescott made the best BB Mopar oil pump out there. I have tried them all. Milodon, Indy, KB, Titan, and Melling. For me it iwas hands down the best we have ever used. Unfortunately he no longer makes them. The one I have not tried and have heard good things about from Stock and SS buddies is Jones Engine Development pumps. Here is a link to them. Unless you can get Charlie to take time to build some more. http://www.jonesenginedevelopment.com/products.html
Re: BB Oil Pumps
[Re: Al_Alguire]
#2172832
10/12/16 12:23 PM
10/12/16 12:23 PM
Posts: 3,456 Out West
408strokerdart
Out West
IMO Charlie Wescott made the best BB Mopar oil pump out there. I have tried them all. Milodon, Indy, KB, Titan, and Melling. For me it iwas hands down the best we have ever used. Unfortunately he no longer makes them. The one I have not tried and have heard good things about from Stock and SS buddies is Jones Engine Development pumps. Here is a link to them. Unless you can get Charlie to take time to build some more. http://www.jonesenginedevelopment.com/products.html Do you have any information on the Wescott pump? Just wondering what made it special or the best in your opinion. Anyone out there still have one of these things they could take some pictures of?
Re: BB Oil Pumps
[Re: dvw]
#2172904
10/12/16 02:16 PM
10/12/16 02:16 PM
408strokerdart
Out West
Mine runs a single line Indy with tall rotor iron replacement pump. At 300 passes the motor was freshened. It sees 7100 every pass. I had broken some valve springs and the debris went thru the pump. The rotors and cover were chewed bad. The rotors were replaced, the Indy cover milled. Even messed up it had 65 psi@7000. I also found the relief spring was broken in half. No other issues were caused by any debris in the motor as it was trapped in the filter. Now with new rotors and a spring it holds 65psi@1500, 80@7000. And to get it that low one coil was removed from the relief spring. It runs 5w30 with .004"main,.003" rod, .0025 lifter clearances. Doug Doug, That is the exact set-up I currently have. Something went thru the pump because the rotors were chewed up and the pump housing is grooved pretty bad. Still carried decent oil pressure. Looking for the best fix to this problem. Sounds like I can get away with just replacing the pump. The Indy cover does not have much damage/wear.....seems to mostly be contained to the housing and rotors.
Re: BB Oil Pumps
[Re: pattyboy 572]
#2172990
10/12/16 04:17 PM
10/12/16 04:17 PM
Posts: 9,861 MI, usa
dvw
MI, usa
Run a filter in the line right out of the pan ,got the idea from al (Hemitis)an inexpensive earls from summit Personally a filter on the suction side scares me. I'd rather have dirty oil than no oil. It might work just fine, but? Doug
Re: BB Oil Pumps
[Re: Al_Alguire]
#2173020
10/12/16 04:54 PM
10/12/16 04:54 PM
Posts: 66 Oklahoma
66 Belvedere
Oklahoma
IMO Charlie Wescott made the best BB Mopar oil pump out there. I have tried them all. Milodon, Indy, KB, Titan, and Melling. For me it iwas hands down the best we have ever used. Unfortunately he no longer makes them. The one I have not tried and have heard good things about from Stock and SS buddies is Jones Engine Development pumps. Here is a link to them. Unless you can get Charlie to take time to build some more. http://www.jonesenginedevelopment.com/products.html Jones only legal in SuperStock. Internal on Stock. Eric's stuff is great. Ray
Re: BB Oil Pumps
#2173044
10/12/16 05:37 PM
10/12/16 05:37 PM
Al_Alguire
Las Vegas
Wescotts deal was a single -16 line used Helical gears as well. Never saw the oil pressure fluctuate at all on my junk with his pump. Wish I could get another one or two honestly. But he is no longer making them. So Jones or Titan it is..
