Rear drum to disc brake convert, what do you guys recommend?
#2172702
10/12/16 05:06 AM
10/12/16 05:06 AM
Posts: 84 Norway
cudaerik
Norway
Looking for a basic drum to disc brake conversion kit (with park brake) for my 1970 Plymouth Cuda with a Chrysler 8.75 rear end.
What do you guys recommend?
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600) 1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600) 1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: Rear drum to disc brake convert, what do you guys recommend?
[Re: cudaerik]
#2172769
10/12/16 11:01 AM
10/12/16 11:01 AM
Posts: 84 Norway
cudaerik
Norway
Looking at the doc. diff page it looks like he's sold out of the kit that fit 15" wheels. Witch kit have you guys installed?
[Re: cudaerik]
#2173442
10/13/16 09:51 AM
10/13/16 09:51 AM
crabman173
crabman173
Why? Disc front and drum rears works wonderful and is easy / cheap so why? If your roadrace at a track well then you need it but otherwise it is just not needed Keep that cash in your pocket!
[Re: ]
#2173469
10/13/16 10:55 AM
10/13/16 10:55 AM
Posts: 2,592 None
71rm23
None
Why? Disc front and drum rears works wonderful and is easy / cheap so why? If your roadrace at a track well then you need it but otherwise it is just not needed Keep that cash in your pocket! I agree with crabman. Did the same with mine and got them from Dr. Diff. Cass is great and great service too.
[Re: 71rm23]
#2173592
10/13/16 01:40 PM
10/13/16 01:40 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Why? Disc front and drum rears works wonderful and is easy / cheap so why? If your roadrace at a track well then you need it but otherwise it is just not needed Keep that cash in your pocket! I agree with crabman. Did the same with mine and got them from Dr. Diff. Cass is great and great service too. I too have done the all drum to disk / drum conversion and unless you are punishing your brakes with road racing or 140 mph blasts down the quarter mile with a short shut off area, a stock well maintained system with ceramic pads and shoes is all you really need. Save your money... JMHO
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: cudaerik]
#2173757
10/13/16 04:45 PM
10/13/16 04:45 PM
Posts: 84 Norway
cudaerik
Norway
Thanks for the advice guys!
