New Build Issues Tear Down and Assessment
#2172521
10/11/16 11:00 PM
10/11/16 11:00 PM
Porter67
Hi guys... crazy day. I posted about some material in my oil filter... https://board.moparts.org/ubbthreads/ubbt...tml#Post2171150 So a friend tossed me a new filter today and I popped it one, 20 minutes run time pretty good. Cut open filter and some more of the same thin flexible material, so its down to the short block and i will have it fully apart tonight with pics. I had a thought in the post in the link above that it might be the wiseco skirt coating as in the past I had a set of piston that it wanted to come off for what seemed like no reason. Sure enough I can see past the cam to see a small bit on the skirts missing but zero scuffs in the skirts, just as in a prior build with the same pn slugs. They say they can go as tight as .004 at build time I was at .0055 and Ive always made dame sure the lower bore was not sharp..... I had run this on my test stand as I planned on doing an inspection due to my unconventional top end and im happy to report on that all looked good with the exception of I found out cometics wont seal around the oil hole on the 10th use as I seen it pushed some oil out into gasket area. So what do you think is jacking the skirt coating on my wiseco pistons? Ive alot of pics and questions I will post tonight as well as I will remeasure my skirt to bore at the bottom for like the 5th time. Better catch it now then later and I think maybe the little bit in the filter was less then before and it might of been ok...
Re: New Build Issues Tear Down and Assessment
[Re: Porter67]
#2172590
10/12/16 12:23 AM
10/12/16 12:23 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Is that the "Grafal" coating on the Wisecos?
Mopar to the bone!!!
[Re: Porter67]
#2172663
10/12/16 01:42 AM
10/12/16 01:42 AM
Porter67
I edited this because I went out this am and took a few more pistons out, ive got .0055 on 7 out of 8 and one a hair less then .0055.
The spec card says they can go .0035.
I can flake off there armor coating with my finger nail in good sized pieces.
In the pics you can see the grooves from the piston skit thats like new.
The coating just isnt sticking?
Any ideas?
[Re: Porter67]
#2172877
10/12/16 01:36 PM
10/12/16 01:36 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Yup, I'd call wiseco and get their take on it .
Worse case scenario.......if that's the only thing you find...... Just remove the coating and put it back together.
[Re: Porter67]
#2172913
10/12/16 02:29 PM
10/12/16 02:29 PM
Posts: 43,275 Bend,OR USA
Cab_Burge
Now after all that fuss, I got to ask myself is it worth the downtime and hastle vs just cleaning the junk off and running them.
Id like to get this thing in the car and some runs before the snow hits. It's your call, remove and run and send them back later or remove and run and forget about it If you remove the coating how much more piston to cylinder wall clearances will you end up with?
[Re: Porter67]
#2172920
10/12/16 02:34 PM
10/12/16 02:34 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Good to see they are top notch.
Nice find and congrats on. A new build coming together. looks like it's going to run hard.
[Re: FastmOp]
#2172924
10/12/16 02:39 PM
10/12/16 02:39 PM
Porter67
Call the piston Manufacturer. I did and they already sent the ups label to print. Im gonna go clean one and see where im at on clearance and go from there. Im just really glad to have an answer as to why it came off, I had a good little bit on the bottom of the pickup as well. Id say 1/3 of the coating came off each skirt in less the 1 hour run time on the test stand.
[Re: Porter67]
#2172942
10/12/16 02:56 PM
10/12/16 02:56 PM
Thumperdart
State of confusion
Id like to get this thing in the car and some runs before the snow hits. I`ve heard of the coating rubbing off eventually and ending up in the oiling system but is no problem because it mixes fine w/the oil.......... Unless the coating took up that much clearance, I`d run it a bit more and change the filter again and beat on it........
[Re: Porter67]
#2173036
10/12/16 05:25 PM
10/12/16 05:25 PM
72Swinger
Nebraska
The coating is never permanent, just should wear WAY more gradually than flakes.
[Re: Porter67]
#2173064
10/12/16 06:19 PM
10/12/16 06:19 PM
Porter67
Flakes, thats an understatement.
My filter had small pieces, the motor is full of flakes. The pickup had a bunch the size of a pinch of tobacco.
So yea, im gonna gut, even pull the cam bearings and just make sure its right.
I removed the coating for one piston and id hit spots where little areas just popped off, the rest I rubbed off with 1500 steel wool in soapy water.
I didnt give up much skirt to wall clearance.
Hey, but ya know what I dont see in the filter pic, trash and metal... I think it would of been a full on go if not for this issue.
[Re: Porter67]
#2173065
10/12/16 06:26 PM
10/12/16 06:26 PM
Porter67
Alot came off each piston, but cleaned up ok.
Not pretty, but...
One of my best service life builds was a simple $1800 Eagle/SRP forged kit, Ive had a bit of trouble with scat and this $2600 K1/Wiseco Kit...Grrrrr.
The only scratches are a few light ones from me removing the rest of the coating.
