leaf springs #2171682
10/10/16 08:59 PM
10/10/16 08:59 PM
Eastern ohio
Alexdodge Offline OP
Eastern ohio
Anywhere near or around pittsburgh that is a good place to get new leaf springs for a 62 dodge polara?
Re: leaf springs [Re: Alexdodge] #2171704
10/10/16 09:40 PM
10/10/16 09:40 PM
IN
ahy Offline
ahy  Offline
IN
It would not hurt to check at a local spring shop or two. I have been surprised what my local shop can get and handle. New springs for a '78 Ford PU, modification of my Challenger springs and rebuild springs for a '47 PW for example.
That said, most folks seem to have best luck ordering from ESPO or "Springs and Things" as it is called.
Re: leaf springs [Re: Alexdodge] #2171898
10/11/16 01:22 AM
10/11/16 01:22 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Before replacing your springs with new ones, you might be happy with one more leaf added to each side. Any 2-1/2" wide leaf of appropriate thickness and length will work.
Re: leaf springs [Re: Alexdodge] #2171948
10/11/16 03:57 AM
10/11/16 03:57 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Just beware that the local spring shop does not mistaken you for their most popular customer. Which is an overloaded 1/2 ton truck needing a stronger spring pack jacked up like a monster truck.
Re: leaf springs [Re: Alexdodge] #2172054
10/11/16 11:57 AM
10/11/16 11:57 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Try Emch Spring in Youngstown Ohio.When I got my 57 they had springs in syock.Cost 100 each.They can make or rearch your springs also.Dealt with them for decades but havent bought anything in about 10 years.They rearched my kids springs and when he sold the 62 they were still better than new after 12 years.Rocky
Chrysler Firepower
Re: leaf springs [Re: therocks] #2172135
10/11/16 01:39 PM
10/11/16 01:39 PM
You might see what they want just to rearch the 2 main leafs. you can C clamp the spring aways back from the center bolt on each side of it then remove the nut then evenly undo the clamps & save yourself some labor & as said adding a leaf is doable. I like to remove the nut with a nut cracker if it is tight rather than risk breaking the special bolt tho the spring shop would carry them. just for reference before starting I would jack up the rear & with your tape see how many inches of increased height you are after. If you go with new springs I would get 1" over stock height. EDIT if adding a leaf you may need center bolts with more threads
Re: leaf springs [Re: Alexdodge] #2172203
10/11/16 03:05 PM
10/11/16 03:05 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The bolt is nothing.Any spring shop will have them.NAPA even had them the last time I did a set.Rocky
Chrysler Firepower
Re: leaf springs [Re: Alexdodge] #2172335
10/11/16 06:41 PM
10/11/16 06:41 PM
Eastern ohio
Eastern ohio
Actually, being that I'm doing a full restoration I just canned the old ones.
Re: leaf springs [Re: Alexdodge] #2173195
10/12/16 10:23 PM
10/12/16 10:23 PM
IN
ahy Offline
ahy  Offline
IN
Youngstown and Pittsburgh are probably spring shop capital cities of the country. I lived and ran a truck in that area some years ago when surrounding roads were among the worst in the country.
Thankfully the roads are much improved now.
Anyhow, on more than one occasion I have rolled into a Youngstown spring shop with a hurting tandem dump with multiple cracked leafs and rolled out less than two hours later with fully rebuilt springs. Heavy hoist around the rear of the truck, lift the wheels clear of the floor and have at it. It was amazing to me how they handled it. They shuffled spring packs like a deck of cards. A good shot of grease in the new bushings and back out the door.
I hope you have the same experience with your project.
