New converter results #2171181
10/09/16 10:49 PM
10/09/16 10:49 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Went 5 rds at Milan today. Car ran 9.0x all day. The suspension and converter combo is coming around. New bullet from Lenny at Ultimate. Went a best of 1.240/5.718@119/9.04/144.33 on the brakes.I had it jetted to lean and a head wind so mph was a little low, 147. This run was .02 quicker than its previous best in the 1/8 when it ran 9.02. The 9.02 was with Pro Systems Holleys as well. Today was on Edelbrocks. Hopefully the weather holds out and we'll get one more shot this year.
Doug
Re: New converter resulrs [Re: dvw] #2171188
10/09/16 10:58 PM
10/09/16 10:58 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Great job, Doug, wish they'd run 1/4 mile down here!
Re: New converter resulrs [Re: dvw] #2171193
10/09/16 11:06 PM
10/09/16 11:06 PM
N.E. Ohio
OhioGTX Offline
OhioGTX  Offline
N.E. Ohio
Nice runs!
68 GTX, 9.38 at 144, Best Machine 540..
Re: New converter resulrs [Re: dvw] #2171195
10/09/16 11:07 PM
10/09/16 11:07 PM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
haulin the mail you are..... nice!!
Re: New converter resulrs [Re: dvw] #2171332
10/10/16 06:32 AM
10/10/16 06:32 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
You had some good air to run in I think didn't you?
Re: New converter results [Re: dvw] #2171358
10/10/16 10:17 AM
10/10/16 10:17 AM
NC USA
U
ultimatelenny Offline
U
NC USA
Congrats doug, looks like we have something to work with up
Lenny Croteau www.ultimateconverter.com Phone 704-892-6837 Fax 704-892-6880
Re: New converter results [Re: dvw] #2171381
10/10/16 11:24 AM
10/10/16 11:24 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
72 Plymouth Roadrunner 11.08@123.25
Re: New converter results [Re: dvw] #2171423
10/10/16 12:40 PM
10/10/16 12:40 PM
gregsdart Offline
gregsdart  Offline
Doug, what did you change in the converter?
Re: New converter results [Re: dvw] #2171445
10/10/16 01:19 PM
10/10/16 01:19 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I've been running a borrowed ATI 9.5". Lenny made me a new converter same core. It was about 400 rpm tighter than the ATI. Lenny suggested changing the stator which he took care of. Though it's still slightly tighter than the ATI early looks appear that it may be better. ATI flash 6200, fall back 1/2 6300 2/3 6400. Ultimate flash 6000 1/2 6200 2/3 6250.
Doug
Re: New converter results [Re: dvw] #2171471
10/10/16 02:13 PM
10/10/16 02:13 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Hey doug looked for you when we where leaving but couldn't find you. Nice going on the rounds and getting that thing to come around. on our last run the 60's fell from 1.23 to a tire spinning 1.45 so we where done for the day because we couldn't run the number.
JAKES AUTOMOTIVE
Re: New converter results [Re: JAKE68] #2171630
10/10/16 07:08 PM
10/10/16 07:08 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I came down in between rounds and you guys were gone. I loosened the shocks after rattling the tires on the first hit. That fixed the starting line but down track felt loose.
Doug
Re: New converter results [Re: dvw] #2171649
10/10/16 07:53 PM
10/10/16 07:53 PM
tboomer Online work
tboomer  Online Work
Nice!! What was the DA Doug?
Re: New converter results [Re: dvw] #2171684
10/10/16 09:07 PM
10/10/16 09:07 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Very good. Between 300-1250ft. That's the strange part. It's run better mph this year at 3000Ft. That's why I believe it to be lean.
Doug
Re: New converter results [Re: dvw] #2171719
10/10/16 10:00 PM
10/10/16 10:00 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The DA doesn't matter as much as the water grains. 1200ft air could be junk compared to 3000ft air depending on the GOW
Re: New converter results [Re: Monte_Smith] #2171761
10/10/16 10:42 PM
10/10/16 10:42 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
My Big Dummy of The Day question: Is there a correlation between GOW and Relative Humidity?
Re: New converter results [Re: BradH] #2171766
10/10/16 10:47 PM
10/10/16 10:47 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Yep, it depends on the temperature.
http://www.engineeringtoolbox.com/water-vapor-air-d_854.html
Re: New converter results [Re: BradH] #2171767
10/10/16 10:48 PM
10/10/16 10:48 PM
fullmetaljacket Offline
Congrats D. Lenny's products are great and he's even more greater to work with.
Re: New converter results [Re: dvw] #2172023
10/11/16 11:15 AM
10/11/16 11:15 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
I was surprised that our car had 1.23 60's then first round blew the tires off and went 1.45 and rick couldn't run the number. looked like we where getting way too much body speration so I tightened the rear shocks one click but we didn't want to wait 2 hrs for another licence pass. so we left and will have to get back out.
JAKES AUTOMOTIVE
Re: New converter results [Re: dvw] #2172029
10/11/16 11:32 AM
10/11/16 11:32 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
The worst 60 ft was 1.28. Bill stood the Rambler up later in the day 300 ft out and smashed the pan. This is the best I've seen Milan.
Doug
Re: New converter results [Re: dvw] #2172078
10/11/16 12:36 PM
10/11/16 12:36 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
The car continues to be totally impressive - that is flat out flying for an NSS legal car - the 8 second time slip is coming pretty soon - no doubt! Congrats Doug!
