Re: 904 Low Gear Set
[Re: GoDartGo]
#2171657
10/10/16 08:05 PM
10/10/16 08:05 PM
RapidRobert
If no one answers, Google it & pics/info will come up
[Re: GoDartGo]
#2173163
10/12/16 09:42 PM
10/12/16 09:42 PM
dogdays
They made a million transmissions with the low gearset, should not be too expensive for someone to mail you a set wherever Over There is.
R.
[Re: GoDartGo]
#2173990
10/13/16 08:32 PM
10/13/16 08:32 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
The 6 cylinder trannys have the lo gear set and ork in the 727. I ran them in a small block barracuda. made a noticeable difference.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
[Re: BB65Barracuda]
#2174190
10/13/16 11:54 PM
10/13/16 11:54 PM
Posts: 4,672 Wichita
GY3
Wichita
A local transmission shop charged me $50 for a used sun gear and planetary for my 904 years back. It wasn't worth the effort in a street car.
[Re: BB65Barracuda]
#2174192
10/13/16 11:54 PM
10/13/16 11:54 PM
GY3
Wichita
The 6 cylinder trannys have the lo gear set and ork in the 727. I ran them in a small block barracuda. made a noticeable difference. A factory low gear in a 727?!
[Re: BB65Barracuda]
#2174618
10/14/16 04:05 PM
10/14/16 04:05 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The 6 cylinder trannys have the lo gear set and ork in the 727. Nope
[Re: GoDartGo]
#2174687
10/14/16 05:37 PM
10/14/16 05:37 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
There was someone that took the 904 low gear set and managed to make it fit the 727 with a lot of machining and splicing of 904/727 parts and welding.
But stock?
Nope
There are aftermarket low gear sets for the 727, but not cheap.
[Re: Supercuda]
#2175793
10/16/16 08:25 AM
10/16/16 08:25 AM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
But stock?
Nope
There are aftermarket low gear sets for the 727, but not cheap. Both of you are incorrect as I drove the car with the modified low gear set up behind my 340 in my car at the track for 3 years.
