Re: MOVING AXLE BACK [Re: MR_P_BODY] #217178
02/08/09 01:26 PM
02/08/09 01:26 PM
ohio
mike67net Offline
mopar addict
mike67net  Offline
mopar addict
ohio
Put a spacer in front of the spring hanger, 1/2" alum.
I hope your drive shaft was a touch long
That's how I moved mine back, it's easy.
Mike
Re: MOVING AXLE BACK [Re: deaks] #217179
02/08/09 01:36 PM
02/08/09 01:36 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: MOVING AXLE BACK [Re: BBLM23] #217180
02/08/09 06:50 PM
02/08/09 06:50 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I think i would rather do the alteration than alter the bodywork.
BBM
What size tyres are they.
Mike
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: MOVING AXLE BACK [Re: deaks] #217181
02/08/09 06:55 PM
02/08/09 06:55 PM
BBLM23 Offline
BBLM23  Offline
The tires above are 28x13.5.
Moving the tires back didn't make sense to me.
These are 30x13.5:
Walter
1981 Reliant 400
Re: MOVING AXLE BACK [Re: BBLM23] #217182
02/08/09 07:04 PM
02/08/09 07:04 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
What is the full width of your tyres and what rims are they on.
best 60ft 1.36
Re: MOVING AXLE BACK [Re: deaks] #217183
02/08/09 07:07 PM
02/08/09 07:07 PM
BBLM23 Offline
BBLM23  Offline
MT ET Streets 30x13.5x15 on a 10 inch rim. My Dart is mini-tubbed. Leaf springs moved into frame rail.
Walter
1981 Reliant 400
Re: MOVING AXLE BACK [Re: BBLM23] #217184
02/08/09 07:18 PM
02/08/09 07:18 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Is that the width including the tyre bulge on the rim, my 10.5 MT's measure just over 13" at their widest point.
best 60ft 1.36
Re: MOVING AXLE BACK [Re: deaks] #217185
02/08/09 07:25 PM
02/08/09 07:25 PM
BBLM23 Offline
BBLM23  Offline
13.5 at the bulge...
Walter
1981 Reliant 400
Re: MOVING AXLE BACK [Re: MR_P_BODY] #217186
02/09/09 01:44 PM
02/09/09 01:44 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
thanks for the answer mike! now, i will be lenghtening the rear segment is that going to cause problem in you opinion? soften the spring rate? since it's for cosmetics basiclly, i don't want to create problems! thanks again, dave
