Big block. Cyl 5/6 header bolts into cooling?
#2170759
10/09/16 06:29 AM
10/09/16 06:29 AM
Posts: 8,852 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Put headers on the 440. Cyl 5 and 6. Has bolts. Rest are studs. The bolts go into water jackets right? Pipe tape or something else?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: Big block. Cyl 5/6 header bolts into cooling?
[Re: roadhazard]
#2170844
10/09/16 12:40 PM
10/09/16 12:40 PM
RapidRobert
I believe all OE iron BB head ex bolt holes are wet. What about using OE shouldered double male studs in em as they do seal very well (with some cement). You can trim the outer fine threaded end to where just enough thread length is left to where with the header/gasket/nut installed/torqued, the nut fits flush on the thread end (grab your tape). trim as needed before installation. when done, any threads protruding past flush with the nut is a waste & greatly hampers header fitment, either flange going over the bolt and or bolt thread interference with header tube. & there are thinner high grade nuts for further clearance help
[Re: toplescuda]
#2170860
10/09/16 01:18 PM
10/09/16 01:18 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
I use studs even on my aluminum heads.Only place I use a bolt is where studs dont work.IIRC Its one.When i ran bolts i use silver anti sieze and went years with no leaks.That and they come right out after years of running.Rocky
Chrysler Firepower
[Re: toplescuda]
#2171059
10/09/16 08:21 PM
10/09/16 08:21 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Stock motor. All are studs but just them 2 cyl. So will have to have a bolt. Just wanting to know if the Teflon tape will hold up and keep it sealed
[Re: Dave Hall]
#2171318
10/10/16 03:43 AM
10/10/16 03:43 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
I always used some high temp rtv? Seemed to work back in the day. I think the tape would work. Where can it go? Even if it gets hot it's not going to flame out and disintegrate. It's stuck between the threads right? This ^^ I use Ultra Copper RTV, it handles the heat and I coat the the whole bottom of the bolt/stud so it stops corrosion of the bolt that is in the water.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: toplescuda]
#2171326
10/10/16 05:20 AM
10/10/16 05:20 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
Thanks guys. That's all I needed to know
[Re: moparx]
#2172156
10/11/16 02:09 PM
10/11/16 02:09 PM
RapidRobert
^this^ I ain't used it (yet) but as said it is (been) highly recommended by many people
[Re: toplescuda]
#2172394
10/11/16 08:03 PM
10/11/16 08:03 PM
Posts: 635 mississippi
bentwheel43
mississippi
I always use red RTV for that.
Section 8 Racing We are nuts about racing.
