Re: TDC ??
[Re: seeker]
#2170573
10/08/16 09:46 PM
10/08/16 09:46 PM
RapidRobert
Am I correct thinking TDC @ 1 will have number 6 I&E rocking ? for ignition timing purpose ? Yes, if the dampener slit is pretty close to TDC & #6's are rocking then you are on TDC #1 compression. As Cab said backup the dampener a bit to 15 (I like to backup to 20 then come forward to 15 to elim chain slop) then turn the dist housing till the magnet is lined up dead even with the tooth and as you know at that point you want the rotor under or near under the dist cap terminal with the #1 plug wire above it & vac adv shifts rotor phasing CW on a BB so ideally you'd want the rotor at rest to be on the CCW edge of the cap terminal like Cab said. prior to this I would clock the intergear so #1 plug wire is clocked in the cap at the OE position (helps prevent future mistakes & at least on a SB lets the wires nestle as neat as possible with the shortest lengths possible) & iirc on a BB #1 points sideways/transverse across to the drivers side and one of the dist cap holddown straps is at 5 o'clock with you standing at the pass fender looking down at it.
Re: TDC ??
[Re: seeker]
#2170902
10/09/16 02:01 PM
10/09/16 02:01 PM
RapidRobert
what ign is in there now? with dampener on 15/# 6's rocking/magnet lined up/rotor on #1, all the items we covered, if all good there then the long block is OK & lets concentrate on the ign setup. is it being fed in ign2 "crank" & ign1 "run"? is the ign system itself wired correct? is it timed right (trigger point). holler back when you can. EDIT please tell me this ain't a new cam breakin (we've did alot of no start cranking). Are the plugs still clean? MORE EDIT no vac leaks/getting good fresh gas?
Re: TDC ??
[Re: RapidRobert]
#2171980
10/11/16 09:39 AM
10/11/16 09:39 AM
Posts: 14 IA Iowa
seeker
IA Iowa
Not recent rebuild is a 2007 build and has ran fine till now, things done just b4 trouble new front end with some welding done, unsure if the installer removed battery cables etc., also the positive cable from trunk mounted battery shorted out on muffler. Getting this info from owner so not real sure of sequence etc of potential causes that may be reason. However removed the MSD to a self contained dist(Assault style), same results ignition system is getting 10 plus volts while cranking. I have watched rotor for slack, have made sure several times on number 1 to fire, Feel as tho something simple and I am just not recognizing to be clear 2 different entirely ignition systems used, same results..........plenty of fuel, 200#s give or take 5 compression, dropped oil pan, to look for whatever, timing chain still very good as far as stretch, nearly no slack at all, but the rotor showed me as well, instant movement with turning crank either way...........Also have checked for fire at each plug being grounded on block rather than in cylinder.........plugs are clean, no oil or fuel contamination H E L P :-)
Re: TDC ??
[Re: seeker]
#2172174
10/11/16 02:26 PM
10/11/16 02:26 PM
Posts: 43,301 Bend,OR USA
Cab_Burge
When a motor won't start I pull the coil wire from the distributor and hold it 1/8 to 1/4 inch from the heads or intake manifold and use a remote starter switch with the key on to see if I get spark out of the coil first when I spinthe motor over with the starter, if not trouble shoot it, if so move on to the next step in the process of trouble shooting the no start ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) IHTHs
Re: TDC ??
[Re: seeker]
#2172668
10/12/16 01:49 AM
10/12/16 01:49 AM
RapidRobert
However removed the MSD to a self contained dist(Assault style), same results. would you have a Mopar ign system you could swap in just to elim or confirm it is ign (which I'd bet it is)
