Thanks Best Machine and Superformance Gaskets #2168048
10/04/16 10:54 PM
10/04/16 10:54 PM
N.E. Ohio
OhioGTX Offline OP
OhioGTX  Offline OP
N.E. Ohio
Finally was able to make some passes on new Best Machine 540, it met expectations. 9.38@144 mph, I was impressed given the car weighed 3550#s at the starting line. The combo is fairly basic and as always it is a sum of its parts. Chuck and Pete did an excellent job on all the machine work, and parts selection While we did the assembly locally.
Also wanted to thank Greg at Superformance for all the leak free gaskets. And the last minute custom gaskets for the tunnel ram. His customer service is second to none.
The combo:
- Indy Maxx Aluminum Bloc
- 4.25 x 4.5
- Indy 325 CNC Heads
- Best Machine Custom Cam ( 279/750 , 290/730 )
- Indy Tunnel Ram / 2 750 carbs with proform parts.
- 9" Converter
- 4.30 gear
- 13 x 31 tire
- 68 GTX 3550#'s
This combo is 3 tents faster than the previous 499 with Edelbrock Victor Heads and 280/670 cam..
And given the high mph, I have a bunch of work to do on the chassis to reach potential.
68 GTX, 9.38 at 144, Best Machine 540..
Re: Thanks Best Machine and Superformance Gaskets [Re: OhioGTX] #2168185
10/05/16 02:35 AM
10/05/16 02:35 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Sounds like a great running piece you got for sure!!
Re: Thanks Best Machine and Superformance Gaskets [Re: OhioGTX] #2168214
10/05/16 08:28 AM
10/05/16 08:28 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Congrats Mike, your car looks and runs amazing.
Re: Thanks Best Machine and Superformance Gaskets [Re: OhioGTX] #2168291
10/05/16 12:07 PM
10/05/16 12:07 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Happy to be a part of that winning package and appreciate the support Mike!
Re: Thanks Best Machine and Superformance Gaskets [Re: OhioGTX] #2168345
10/05/16 01:40 PM
10/05/16 01:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
NICE................... beer
Re: Thanks Best Machine and Superformance Gaskets [Re: OhioGTX] #2169391
10/07/16 12:45 AM
10/07/16 12:45 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Mike it was nice getting out to the track w/you again. You had your car hauling.
Ok
Re: Thanks Best Machine and Superformance Gaskets [Re: OhioGTX] #2169474
10/07/16 07:27 AM
10/07/16 07:27 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Congrats on your improvement. What were the incremental numbers? How much compression?
Doug
Re: Thanks Best Machine and Superformance Gaskets [Re: dvw] #2169577
10/07/16 01:16 PM
10/07/16 01:16 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Doug
bump for this?
Re: Thanks Best Machine and Superformance Gaskets [Re: OhioGTX] #2169597
10/07/16 01:49 PM
10/07/16 01:49 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Ditto.. full cam specs would be nice as well.
I make that a true 850 hp, that's good numbers.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Thanks Best Machine and Superformance Gaskets [Re: OhioGTX] #2169933
10/07/16 10:28 PM
10/07/16 10:28 PM
N.E. Ohio
OhioGTX Offline OP
OhioGTX  Offline OP
N.E. Ohio
Thanks for the congrats and interest folks. I have attached the time slip for folks interested. The weather on this date was pretty good, DA was at 2000 and grains of water were mid 60's. The compression is 14:1.
I do not have the cam card handy but it is a Custom Comp Cam from Best machine. They have a few grinds and this is one of the smaller ones.
Re: Thanks Best Machine and Superformance Gaskets [Re: OhioGTX] #2169949
10/07/16 10:50 PM
10/07/16 10:50 PM
Mo.
racerx Offline
racerx  Offline
Mo.
link not workie........maybe cause i'm not a facebook member you think?
Re: Thanks Best Machine and Superformance Gaskets [Re: OhioGTX] #2170014
10/08/16 12:10 AM
10/08/16 12:10 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mph and 60 don't look too bad at 3550. My bet is the converter is a little tight. There is more left. got at least a mid .20
Doug
Re: Thanks Best Machine and Superformance Gaskets [Re: dvw] #2170022
10/08/16 12:20 AM
10/08/16 12:20 AM
fullmetaljacket Offline
Take some weight off and he's got some low oh's.
Re: Thanks Best Machine and Superformance Gaskets [Re: OhioGTX] #2170137
10/08/16 10:34 AM
10/08/16 10:34 AM
N.E. Ohio
OhioGTX Offline OP
OhioGTX  Offline OP
N.E. Ohio
Doug - agree on converter. This was tight behind my 499 and also tight behind my friends 572. It provided the data needed to order the next one..Hopefully we get it right and it helps.
Also, love your car, watched it run many times. Nice work!
Re: Thanks Best Machine and Superformance Gaskets [Re: OhioGTX] #2170326
10/08/16 03:08 PM
10/08/16 03:08 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
What rear suspension ?
best 60ft 1.36
