Re: 08 5.7 PCV valve ?
[Re: TrxR]
#2172210
10/11/16 03:11 PM
10/11/16 03:11 PM
Posts: 1,647 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
The PCV valve (4) is mounted into the top of the intake manifold (1). This is located to the right / rear of the throttle body (2).
1. The PCV valve is sealed to the intake manifold with 2 O-rings (2).
2. Remove PCV valve by rotating counter-clockwise 90 degrees until locating tabs (3) have been freed. After tabs have cleared, pull valve straight up from intake manifold.
3. After valve is removed, check condition of 2 valve O-rings (2).
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: stumpy]
#2175038
10/15/16 02:44 AM
10/15/16 02:44 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
You can do a "how to" search online and find videos showing how. I have done that for a lot of projects. I've done it too. YouTube has all sorts of great videos but there are some idiots there as well.
