Push-Loc Hose on trans lines #216953
02/07/09 08:00 PM
02/07/09 08:00 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
Anyone use it..Looks like a good deal ???
Re: Push-Loc Hose on trans lines [Re: VernMotor] #216954
02/07/09 08:29 PM
02/07/09 08:29 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i did coz i was told they'll never fail. WRONG! the hot fluid popped it off whilst the brake was on. luckily i didn't release the brake or i coulda had armco rash on my dart. only use the reusable fittings now with braided line. once bitten ....
Re: Push-Loc Hose on trans lines [Re: rebel] #216955
02/07/09 08:35 PM
02/07/09 08:35 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
OK thats what I want to know .I also have a trans brake on the car,,they say it is good to 250psi..I wonder..How that would hold up..
Re: Push-Loc Hose on trans lines [Re: rebel] #216956
02/07/09 08:43 PM
02/07/09 08:43 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i've had 2 failures with the pushloks vern. the first was with the external oiling on my indy heads, spewed oil everywhere, changed them to braided hose & fittings. the second was with the trans, shop man said the oil lines must have been badly assembled & he fitted my pushloks himself & told me they'll never fail. BS. he did take them back tho & credited me against the braided lines. maybe i'm just unlucky or maybe the fittings i bought were chineese knock offs , but i'm staying away from pushloks forever now.
Re: Push-Loc Hose on trans lines [Re: rebel] #216957
02/07/09 10:13 PM
02/07/09 10:13 PM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
We are running the aeroquip black push lock fittings with glide with brake and had no problems in 3 years. I have been told if you use the blue hose you need to use the locking rings as the heat stretchs the blue hose. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: Push-Loc Hose on trans lines [Re: VernMotor] #216958
02/07/09 11:16 PM
02/07/09 11:16 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
imho i would not use push loc hose for this application...blow one off at speed and it won't look like such a good deal
Re: Push-Loc Hose on trans lines [Re: Mopar_racer_99] #216959
02/08/09 12:25 AM
02/08/09 12:25 AM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
i have been running the blue hose for 4 years with 0 issues. and pushloc fittings
Re: Push-Loc Hose on trans lines [Re: prochargedhemi] #216960
02/08/09 04:18 PM
02/08/09 04:18 PM
California, USA
blairboy3 Offline
blairboy3  Offline
California, USA
aeroquip blue hose (350psi rated I believe... have to go out & look @ the stuff on the wall) & aeroquip push-loc fittings on all my fuel & tranny lines. No problems in 3 years.
1968 Plymouth Fury III 4-Door: 12.79 @ 115, 60'- 1.93 (Hey... it's a Cruise ship... what do you expect?!) Famoso Raceway, 02/08
Re: Push-Loc Hose on trans lines [Re: blairboy3] #216961
02/08/09 05:02 PM
02/08/09 05:02 PM
CT
turbocolt2.4L Offline
CT
first off if you t-brake has 250 psi that is line pressure not cooler flow/pressure you probably have no more than 35-40 psi in cooler lines.
Re: Push-Loc Hose on trans lines [Re: turbocolt2.4L] #216962
02/08/09 05:25 PM
02/08/09 05:25 PM
MN
hemidup Offline
hemidup  Offline
MN
We've used Push loc's in the past. We also use a crimp on style hose clamp with them to be on the safe side. No problems.
Jerry Williams.
Re: Push-Loc Hose on trans lines [Re: blairboy3] #216963
02/08/09 06:34 PM
02/08/09 06:34 PM
jamesc Offline
jamesc  Offline
at what temperature?
for the difference in price i'll stick with the braided line and have peace of mind.
Re: Push-Loc Hose on trans lines [Re: jamesc] #216964
02/08/09 06:46 PM
02/08/09 06:46 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I have the blue push lock on my trans cooler and my remote oil filter we will see how it does but it is much nicer to work with than the braided stainless as long as I have no problems with it I will never use braided stainless again.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Push-Loc Hose on trans lines [Re: dusturbd340W5] #216965
02/08/09 09:06 PM
02/08/09 09:06 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
The stuff looks nice ..I all the colors .and sounds like it be easy to work with..But I can not take the chance with others Lives..If it was just me and me only driving..I would try it..I might try alittle somewhere.
Re: Push-Loc Hose on trans lines [Re: jamesc] #216966
02/08/09 10:02 PM
02/08/09 10:02 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Absolutely, positively. There is no way I would use pushlock here. NO WAY!
Re: Push-Loc Hose on trans lines [Re: VernMotor] #216967
02/09/09 03:09 PM
02/09/09 03:09 PM
AndyF Offline
AndyF  Offline
I use the Aeroquip socketless hose for most everything these days. Seems to work just fine and I've never seen any issue with fittings coming loose.
