shock travel/velocity vs wheel spin #2169073
10/06/16 05:28 PM
10/06/16 05:28 PM
Winterpeg, Canada
hvyweight Offline OP
Winterpeg, Canada
Does anyone measure and use shock velocity and or travel to limit wheel spin? Dependant on your data logger and electronic system I am wondering if this could be set up so that the computer could monitor such and start pulling out timing managing power as necessary?
For example if the shock separates at a high rate one could pull power out the ramp it back in.
Mike
Re: shock travel/velocity vs wheel spin [Re: hvyweight] #2169133
10/06/16 06:55 PM
10/06/16 06:55 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I would think that if the shock velocity is to high, then you need a better shock. I know that may seem over simplified, but I think accurate.
You need to think about the ultimate goal, accelerating the car as fast as possible. Pulling power wont help that goal.
Re: shock travel/velocity vs wheel spin [Re: hvyweight] #2169147
10/06/16 07:14 PM
10/06/16 07:14 PM
Washington
madscientist Offline
Washington
Mike
Dave Morgan wrote about this extensively a couple of decades ago. I remember he was stumped at some shock speeds when they logged a BB stick car with ladder bars. IIRC, the logger couldn't record it because the speed was so high. So he had to rethink some of what he wrote before he saw those number. Sort of like he had to rethink how to mount a 4 link lower bar.
Re: shock travel/velocity vs wheel spin [Re: hvyweight] #2169211
10/06/16 08:46 PM
10/06/16 08:46 PM
Renton Washington
Triple Threat Offline
Renton Washington
What you want to do sounds the same as what Slew rate programs are designed to do already. You set the rate of acceleration curve, if for some reason the engine is accelerating quicker, timing is pulled to slow it back down to follow the programmed rate. That's the simplistic definition.
MSD 7761 ARC controller or the 7531 both have that functionality.
It is illegal in most classes so finding people with experience is difficult. Look to the fast heads up guys.
As Trendz said, Riding the dots isn't going to be the fastest way down the track, but it will prevent a bad run from becoming a terrible one.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: shock travel/velocity vs wheel spin [Re: hvyweight] #2169262
10/06/16 09:52 PM
10/06/16 09:52 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Since you are only dealing with 2-4 inches of travel, slowing that down with timing might be a little too late. Maybe taking timing out with excessive rear wheel speed acceleration would be better. Or better yet, an ABS system with software that monitors wheel acceleration.
[image][/image]
Re: shock travel/velocity vs wheel spin [Re: hvyweight] #2169398
10/07/16 12:50 AM
10/07/16 12:50 AM
Winterpeg, Canada
Winterpeg, Canada
What happens first? Rear shock extending at a rapid rate or the tire beginning to spin?
Re: shock travel/velocity vs wheel spin [Re: hvyweight] #2169430
10/07/16 01:57 AM
10/07/16 01:57 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
A system that can track wheel speed from a non driven wheel and a drive wheel will probably be the most effective.
This is a cool video showing the capabilities of the MS3PRO EFI. Pretty cool to watch the computer pull timing based on the wheel speed differential.
https://youtu.be/FembJNagxOE
The firebird the video is from is no slouch, 8.50 car.
68 Barracuda Formula S 340
Re: shock travel/velocity vs wheel spin [Re: hvyweight] #2169472
10/07/16 07:23 AM
10/07/16 07:23 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Shock movement occurs before the tire breaks traction.
Doug
Re: shock travel/velocity vs wheel spin [Re: hvyweight] #2169505
10/07/16 10:19 AM
10/07/16 10:19 AM
michigan
turbo toad Offline
turbo toad  Offline
michigan
I know theres alot of people that use liner lasers like the banner Q50,or some sort of string gauge to monitor shock and front end travel and use that data along with some sort of a rpm signal via the drive shaft or pinion,transmission yoke and pull timing to avoid pulling a big wheelie or tire spin.
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: shock travel/velocity vs wheel spin [Re: dvw] #2169531
10/07/16 11:28 AM
10/07/16 11:28 AM
Winterpeg, Canada
Winterpeg, Canada
Doug
Spot on! That's why I am thinking about a way to manage power using shock velocity rather than a wheel spin situation to manage power. One concern I have is bumps or depressions in the track surface. I guess one could filter that out with certain parameters and go from there.
