Re: 318 Step by step PLEASE!
[Re: Crabra]
#2168950
10/06/16 01:47 PM
10/06/16 01:47 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
google lists multiple examples.
Either online builds or links to hard copy books on how to do it.
[Re: Crabra]
#2168992
10/06/16 03:08 PM
10/06/16 03:08 PM
Posts: 6,988 Warren, MI
Jerry
Warren, MI
duplicate
[Re: Jerry]
#2169002
10/06/16 03:20 PM
10/06/16 03:20 PM
Posts: 330 Indiana
Crabra
Indiana
I am going to change piston.Want to be zero deck.
[Re: Crabra]
#2169011
10/06/16 03:26 PM
10/06/16 03:26 PM
Posts: 3,344 Central TX
roe
Central TX
I don't want to stroke it. Don't want to seem like I'm pushing it on you but the price to do a full rebuild on stock stroke and building a stroker are basically the same. The motor in my car now is a 360 based 408 stroker. After feeling the power on tap while still having a streetable motor I will never go back to a stock stroke motor. EDIT: Besides, no one will know it's a stroker but you
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: Crabra]
#2169034
10/06/16 04:03 PM
10/06/16 04:03 PM
Posts: 43,300 Bend,OR USA
Cab_Burge
Do you want 300 HP net or gross HP at the flywheel or the 300 net at the rear wheels? What does the current motor have on it now, IE carb and intake, exhaust, compression ratio and cam?
[Re: Cab_Burge]
#2169038
10/06/16 04:13 PM
10/06/16 04:13 PM
Posts: 330 Indiana
Crabra
Indiana
Stock bottom end,J heads 1.88 int. 160 exh.Performer intake,600 cfm edelbrock,340 hi po manifolds and dual exhaust.3.55 sure grip 8 3/4.Cam is a purple shaft 260/268 duration 430/450 lift
[Re: Crabra]
#2169042
10/06/16 04:21 PM
10/06/16 04:21 PM
Posts: 1,322 Michigan
crlush
If you run flat tops at zero deck with j heads your not going to have much compression, if your going to run zero deck get a set of closed chamber edelbrock heads.
[Re: Crabra]
#2169048
10/06/16 04:31 PM
10/06/16 04:31 PM
crlush
Stock bottom end,J heads 1.88 int. 160 exh.Performer intake,600 cfm edelbrock,340 hi po manifolds and dual exhaust.3.55 sure grip 8 3/4.Cam is a purple shaft 260/268 duration 430/450 lift I have a valiant and used to run a 318 stock heads cut down to raise compression and added a camshaft similar to yours with headers and a good convertor with 391 gears while I don't know what hp it had but would run 14.50 ets quarter mile and would run 13.20 with a 125hp shot of nos.
[Re: Jerry]
#2169076
10/06/16 05:32 PM
10/06/16 05:32 PM
DaytonaTurbo
Manitoba, Canada
why not stroke it if your going to change the pistons anyway? a stroker crank is only a few $100 more and then the investment is done. He can hit his power goal without the stroker. More is better but for 300hp this is not a deal breaker.
[Re: DaytonaTurbo]
#2169105
10/06/16 06:11 PM
10/06/16 06:11 PM
dogdays
Either a set of KB 167 pistons or other flattops with 1.81 compression height. That gets the piston to 0.012" below deck. With the Mr. Gasket 0.028 head gasket you have 0.040 squish if you ever decide to go closed chamber. That's with a deck of 9.600. To build a decent engine you have to take care and the first step is checking your main bearing alignment. Then have the block decks squared up to the crank and to each other. That way you have everything where it's supposed to be. Piston swept volume is 661.6 cc and to get a true 9.5:1 compression you can have no more than 77.8 cc above the piston. Your 360 heads could be as much as 73cc. You need to cut the heads to 63cc if your pistons have 5cc in the valve notches. For a camshaft I'd ask Hughes. I'm guessing that something with intake duration in the low 220s would be the ticket. There are a myriad of 318 buildups online. The one most appropriate for you is this one, no stroker and no Mag heads: http://www.hotrod.com/articles/mopp-0311-318-engine-buildup-and-dyno-test/I'm sure that there have been other 400hp 318 articles using 360 heads. One final observation: You are leaving power and driveability on the table by your choices. It'd be much easier to make 400hp with a 390 shortblock, and it will be much stronger on the street, because the torque curve starts earlier in the rpm range. R.
[Re: Crabra]
#2169186
10/06/16 08:12 PM
10/06/16 08:12 PM
Cab_Burge
3.91 gears are in the works.Best 1/4 mile with 3.55 gears is 15.86 at 89 mph I would look closely at your fuel system to make sure the in tank sock filter and lines up to the pump are good and not plugged up The best way I know of testing the complete fuel system is to be able to fatten the jetting up on teh carb enough to make the 1/4 MPH slow down, if it will your good If it won't, fix it
[Re: Crabra]
#2169251
10/06/16 09:37 PM
10/06/16 09:37 PM
Posts: 4,457 Washington
madscientist
Washington
You will need to run the piston about .040 to .055 out of the hole. Don't be afraid to do it. Use 10:1 compression. Order a cam from Jim at Racer Brown FOR YOUR APPLICATION. If you have manual steering you need Hooker 5204 headers. Power steering...IDK. With a 3.90 gear you can use a single plane intake. Cam accordingly.
[Re: madscientist]
#2169273
10/06/16 10:03 PM
10/06/16 10:03 PM
dogdays
For a 318 I'd go Performer RPM and leave it at that. No reason to gamble on a single plane.
Shoot, the mid '70s cast iron 360 EGR 4-barrel manifold was good for something like 390 hp in the Junkyard Jewel article. It's a real high rise design. It's super heavy but then again I got mine for $15.00. It's a spreadbore design so T-Quad or Q-Jet or Street Demon are your choices.
Well, for big bucks you can run the piston out of the block, it'll definitely not be a shelf stock piston, OR, you can mill the heads 0.040 to 0.055 to get the cc down to 63 as I suggested. Take your pick. IMHO milling is more simple and direct.
R.
