Page 4 of 5 1 2 3 4 5
Re: Do you fill your oil filters before installing? [Re: NITROUSN] #216824
02/08/09 09:35 PM
02/08/09 09:35 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Well, here`s a little tidbit for y`all right out of the FSM for my truck:
(7) Using a new pressure relief valve gasket,
install the relief valve plug. Tighten the plug to 20
N·m (15 ft. lbs.) torque.
(8) Install oil filter that has been filled with oil.
Is that not from a pump repair section? I believe they want you to do it that way so the crank driven pump does not lose its prime. What does the book state in the maintence section on filter change??
Filter is after the pump. Why would it matter?
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Do you fill your oil filters before installing? [Re: gamagoat6x6] #216825
02/08/09 09:42 PM
02/08/09 09:42 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
BINGO: The filter is after the pump BUT before the oil gets to the bearings from the pump, the filter must first fill so the pump can build pressure to send the oil on to the rest of the engine.
Re: Do you fill your oil filters before installing? [Re: MoparforLife] #216826
02/08/09 11:36 PM
02/08/09 11:36 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Man I cant wait till spring, I think we all need to go outside!
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Do you fill your oil filters before installing? [Re: mopargem] #216827
02/08/09 11:39 PM
02/08/09 11:39 PM
& prime our engines
Re: Do you fill your oil filters before installing? [Re: RapidRobert] #216828
02/09/09 03:35 PM
02/09/09 03:35 PM
Hatfield,Pa.
bigD Offline OP
bigD  Offline OP
Hatfield,Pa.
WOW,thanks for all the replys. My intention was not to start such a heated debate as to "yes do it","no don't do it" (because I have used both methods),it was to see if I'm the only one who does.Well it turns out I'm not,but that doesnt mean installing the filter dry is incorrect either(we did it all the time at a dealership I once worked at).It all boils down to whatever works for you.Now we can move on to more important things such as ,D.
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
Re: Do you fill your oil filters before installing? [Re: Pacnorthcuda] #216829
02/09/09 03:39 PM
02/09/09 03:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Not out to change anyones mind, just find it interesting. Kind of a sharing of experiences/practices/ideas. Oh wait thats Moparts!
I am surprised this thread has continued so long, and yea I am part of the reason--so are you John! Enjoy
that's fine as long as others WANT to hear what one has to say/thinks ...
Re: Do you fill your oil filters before installing? [Re: Aero426] #216830
02/09/09 04:12 PM
02/09/09 04:12 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
never fill mine ever on hemi or 440, spin on new filter, pull coil wire and turn key. all filled and primed, put back coil wire all done and fire
I do the same thing, I try to wet the filter though. I dont have a 440 anymore but will soon. I fill the filter on the 273 3/4, still pull the coil and turn it over though.
Re: Do you fill your oil filters before installing? [Re: GTX MATT] #216831
02/09/09 04:35 PM
02/09/09 04:35 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
I will raise the bar further...
Do you pre-oil that big dollar engine with an accusump before cold starting??
Accusump
Re: Do you fill your oil filters before installing? [Re: GTX MATT] #216832
02/09/09 04:37 PM
02/09/09 04:37 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Why in the world do so many people pull the coil wire and crank the engine???? Talk about engine damage, start the darn thing and get that oil pump working asap, plenty of oil left on the bearings. Mopar RB engins have been around since 1959, you think the dealers ever did this in the shop? Have you heard of a bearing failure epidemic?
Better question here is lets talk about when we change the oil, do it on a hot engine, let it drain, then refill it and start it within an hour. Thats how a repair shop does it. Don't wait overnight or longer to refill and start it. And no cold oil changes.
Re: Do you fill your oil filters before installing? [Re: bigD] #216833
02/09/09 04:52 PM
02/09/09 04:52 PM
My intention was not to start such a heated debate.
Oh it'll get worse, just wait until some of the really earth shattering topics come up. You ain't seen nothing yet
Re: Do you fill your oil filters before installing? [Re: RapidRobert] #216834
02/09/09 04:57 PM
02/09/09 04:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yep , post a picture of a red dot , start a poll , is it RED or green ? 30% of the respondents will say its green they tell you are a moron for thinking it's not ...
Re: Do you fill your oil filters before installing? [Re: JohnRR] #216835
02/09/09 05:05 PM
02/09/09 05:05 PM
Kirkland, Washington
Pacnorthcuda Offline
and you post why?
Re: Do you fill your oil filters before installing? [Re: Pacnorthcuda] #216836
02/09/09 05:07 PM
02/09/09 05:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
and you post why?
The same reason as YOU , I like to hear myself talk even though no one else is listening ????
Re: Do you fill your oil filters before installing? [Re: NANKET] #216837
02/09/09 05:07 PM
02/09/09 05:07 PM
Upper Midwest
Upper Midwest
Add to this most reputable shops fill the filter before installing too.
As for spinning the engine before firing it is a recommended practice in the engine book to do this after changing the oil after winter lay up as a type of prelube but to do so with the spark plugs removed so that there is very little pressure exerted on the crankshaft bearings and the engine spins faster and freer.
Re: Do you fill your oil filters before installing? [Re: JohnRR] #216838
02/09/09 05:10 PM
02/09/09 05:10 PM
and you post why?
You have a point---see someone WAS listening! Hope I didn't disturb the peace!
Re: Do you fill your oil filters before installing? [Re: MoparforLife] #216839
02/09/09 05:14 PM
02/09/09 05:14 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
How about adding this to-the-mix ? ......
It depends on how much compression ratio the motor has. Also ...whether or not the motor is warm ...or was recently fired up.
I always fill the filter(as much as possible on the B-engine. But ALWAYS fill-it to-the-top on my Cummins 5.9.
Re: Do you fill your oil filters before installing? [Re: dOc !] #216840
02/09/09 06:01 PM
02/09/09 06:01 PM
SW Fla.
CYACOP Online content
CYACOP  Online Content
SW Fla.
If the oil left between the 2 surfaces is not enough to lubricate the parts when installing an empty filter, then you need to change oils.
Re: Do you fill your oil filters before installing? [Re: CYACOP] #216841
02/09/09 08:01 PM
02/09/09 08:01 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
OK so filling the filter won't hurt anything, but it is unnecessary, What did they do in the 60's 70's ? Fill the filter and unplug the coil until oil pressure came up, nope.
You can find a piece of paper telling you to do just about anything. American Dental Association says to floss daily, have you flossed lately?
Re: Do you fill your oil filters before installing? [Re: NANKET] #216842
02/09/09 08:10 PM
02/09/09 08:10 PM
So there is nothing benificial about flossing? Poor analogy.
Actually I re-thought that. Thats a great analogy if you're making the point that it is better to pre-oil your filters (even though many don't do it, like flossing)
Re: Do you fill your oil filters before installing? [Re: Pacnorthcuda] #216843
02/09/09 08:31 PM
02/09/09 08:31 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
right, now someone gets it!
