Re: Anybody pushing a stock 340 block hard?
[Re: redruM]
#2168157
10/05/16 01:29 AM
10/05/16 01:29 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
How much you putting through yours? im at 690 on motor and spraying on top of that. Block is 60 over, not filled, studs, stock caps. Havent seen any signs of an issue, around 20 hits so far. mostly stock 727 never been in it, but has valve body and deep pan. stock a body 8 3/4 housing, spool and 30 spline More details PLEASE. That sucker must be flying with 690 PLUS the hit.
[Re: redruM]
#2168163
10/05/16 01:39 AM
10/05/16 01:39 AM
Posts: 171 Columbus, OH
redruM
Columbus, OH
sounds similar to yours, indy headed 422. mine prolly weighs a lot more, all steel with glass bumpers
[Re: redruM]
#2168168
10/05/16 01:48 AM
10/05/16 01:48 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
sounds similar to yours, indy headed 422. mine prolly weighs a lot more, all steel with glass bumpers I'm nowhere near those horsepower numbers.
[Re: redruM]
#2168183
10/05/16 02:31 AM
10/05/16 02:31 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Just stop. Both of you. This is not going to end well.
My 25 year old X block with studded 4 bolts caps is unbreakable....I hope.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: redruM]
#2168189
10/05/16 02:53 AM
10/05/16 02:53 AM
redruM
Columbus, OH
[Re: redruM]
#2168217
10/05/16 08:34 AM
10/05/16 08:34 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
what do you make at the flywheel? Would like to compare combos 40 years of racing and I never dynoed an engine. I'm guessing a hair over 500 give or take a few. I hope to step up to a roller cam over the winter to pick up a few more.
[Re: Porter67]
#2168254
10/05/16 10:46 AM
10/05/16 10:46 AM
MoparBilly
Phoenix, AZ
I heard X blocks were not that good? Are they? I don't know, it was in the car when I got it, and it hasn't broke yet. I'm afraid to hit with as much nitrous as I've sprayed on stock 440 blocks though. Numbers dont lie lets see a et slip that will tell us how much power you are really making
Numbers lie...I can just be like everyone else and claim my car is 400 lbs heavier than it really is!! Everything behind your motor is a time bomb, get rid of the 30 spline asap, I broke that, now I'm tearing up 35 spline spools until 9" money this winter
You're doing it wrong...what 60 foots at what weight? Dead hooking a radial? Ok, keyboard experts: 3095 lbs. on the scale at Norwalk, made this pass at National Trails, don't have DA or weather data. What was I making at the tire? What was I making at the flywheel? When will the block break? When will the 904 break? Where can I find two more tenths?
[Re: redruM]
#2168256
10/05/16 10:51 AM
10/05/16 10:51 AM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
I ran an X block for years. New owner still uses that block. Been beat on for 10-12 years now, at as fast as 140 mph N/A at 3220 weight. Great piece. Sturdy.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: redruM]
#2168258
10/05/16 10:54 AM
10/05/16 10:54 AM
MoparBilly
Phoenix, AZ
Looks heavy, Gary. What's the jetting on your "150 shot"?
Ian would drive around me in the back half...it would still be fun!
[Re: MoparBilly]
#2168282
10/05/16 11:46 AM
10/05/16 11:46 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
Ian would drive around me in the back half...it would still be fun! lol it would be there was some more left in it with the tune ,i need to get some weight of the car and driver lol car is 3200 full street trim and me 360 lbs ,the block was not to happy at this level not sure maybe the fill expanding rebuilding a new engine with a r block should be good for extra 200 hp
[Re: redruM]
#2168340
10/05/16 01:32 PM
10/05/16 01:32 PM
Posts: 11,566 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
What's it weigh? MPH?
When you do see signs of an issue, it won't be subtle.
