Pulsing Vibration #2168034
10/04/16 10:35 PM
10/04/16 10:35 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
My car is making a pulsing vibration under steady acceleration in drive only. Does not do it in 1st or 2nd. 340 with torqueflite. Not there when coasting, only under acceleration and only in Drive. Could it be the torque convertor or driveshaft out of balance? This is a good one.? ? ? ?
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: Pulsing Vibration [Re: 6T9Hemi] #2168050
10/04/16 10:56 PM
10/04/16 10:56 PM
same load (in hg) for the steady accelleration in all gears but acting up in Drive only? Everything as far as you know is the same? WAG, slight fuel starvation. EDIT or tire/wheel balance/wheel bearing issue, loose etc
Re: Pulsing Vibration [Re: 6T9Hemi] #2168061
10/04/16 11:07 PM
10/04/16 11:07 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Do you feel it in your hands or your butt?
Re: Pulsing Vibration [Re: stumpy] #2168064
10/04/16 11:10 PM
10/04/16 11:10 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
eek
TMI
TMI
TMI
TMI
TMI
Don't be the exception.
Re: Pulsing Vibration [Re: stumpy] #2168070
10/04/16 11:15 PM
10/04/16 11:15 PM
My tire man asked me that when I was tracking down a vibration. turned out to be a front ujoint getting ready to let go (& it did)
Re: Pulsing Vibration [Re: 6T9Hemi] #2168130
10/05/16 12:49 AM
10/05/16 12:49 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Has the rear suspension been updated or altered in any way? Incorrect pinion angle will cause a harmonic (pulsing) vibration if the u-joints are not properly phased.
Re: Pulsing Vibration [Re: 6T9Hemi] #2168142
10/05/16 01:02 AM
10/05/16 01:02 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Hands = front end, steering etc. Butt = drive line or rear wheel area.
Re: Pulsing Vibration [Re: stumpy] #2168151
10/05/16 01:14 AM
10/05/16 01:14 AM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
Butt. It's like I'm sitting on top of the vibration. I already replaced U joints.
Re: Pulsing Vibration [Re: 6T9Hemi] #2168195
10/05/16 03:37 AM
10/05/16 03:37 AM
too much shaft end play causing not enough front yoke spline engagement in the trans (I had that causing a vibration for me once). worn extension housing bushing. worn trans mount. throwing out potentials.
Re: Pulsing Vibration [Re: RapidRobert] #2168248
10/05/16 10:25 AM
10/05/16 10:25 AM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
What is the correct length for the driveshaft in a 69 GTS 340 auto?
Re: Pulsing Vibration [Re: 6T9Hemi] #2168353
10/05/16 01:56 PM
10/05/16 01:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The best way to check the length of the shaft is to push in into the trans until it bottoms out and then measure the distance to seat the U joint in the rear end yoke. That shouldn't be more than 1.5"
Re: Pulsing Vibration [Re: stumpy] #2168373
10/05/16 02:18 PM
10/05/16 02:18 PM
What Stump said, you may be OK on that dimention as is. (have it loaded)
Re: Pulsing Vibration [Re: 6T9Hemi] #2168427
10/05/16 03:45 PM
10/05/16 03:45 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
Is there any way that it could be the torque convertor balance? You are basically at a 1 to 1 ratio in drive. Could I be feeling an out of balance convertor in drive where the vibration is lost in first and second.
Re: Pulsing Vibration [Re: 6T9Hemi] #2168431
10/05/16 03:52 PM
10/05/16 03:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think any converter imbalance would be felt more in neutral and worse at higher RPM. Have you checked the trans mount etc?
Re: Pulsing Vibration [Re: 6T9Hemi] #2168483
10/05/16 05:17 PM
10/05/16 05:17 PM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
Just for giggles, drop the belts off your engine, I swore I had a converter or drive line issue, was the alternator!
Re: Pulsing Vibration [Re: 6T9Hemi] #2168486
10/05/16 05:20 PM
10/05/16 05:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Convertor out of balance will be out of balance in all gears ... and in neutral .... moving or standing still ...
Re: Pulsing Vibration [Re: 6T9Hemi] #2168567
10/05/16 07:30 PM
10/05/16 07:30 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
If it wasn't acting up before you had the "U" joints replaced, THAT is the first place to look and most likely culprit provided that nothing else was messed with.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Pulsing Vibration [Re: 6T9Hemi] #2170188
10/08/16 12:07 PM
10/08/16 12:07 PM
Slidell, LA
Ronnman Online content
Ronnman  Online Content
Slidell, LA
Check/replace the transmission to cross member mount. A bad mount/worn rubber will drive you crazy chasing other components for vibration problems.
Ron
Re: Pulsing Vibration [Re: 6T9Hemi] #2170267
10/08/16 01:35 PM
10/08/16 01:35 PM
md
mopars4ever Offline
mopars4ever  Offline
md
flex plate cracked?
Re: Pulsing Vibration [Re: 6T9Hemi] #2170411
10/08/16 05:33 PM
10/08/16 05:33 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
What's the verdict? drinking
