Pulsing Vibration
#2168034
10/04/16 10:35 PM
10/04/16 10:35 PM
Posts: 935 Elizabethtown, KY
6T9Hemi
Elizabethtown, KY
My car is making a pulsing vibration under steady acceleration in drive only. Does not do it in 1st or 2nd. 340 with torqueflite. Not there when coasting, only under acceleration and only in Drive. Could it be the torque convertor or driveshaft out of balance? This is a good one.? ? ? ?
1969 340 4 Speed Swinger R4, black vinyl, white butt stripe, 3:91
Re: Pulsing Vibration
[Re: 6T9Hemi]
#2168050
10/04/16 10:56 PM
10/04/16 10:56 PM
RapidRobert
same load (in hg) for the steady accelleration in all gears but acting up in Drive only? Everything as far as you know is the same? WAG, slight fuel starvation. EDIT or tire/wheel balance/wheel bearing issue, loose etc
[Re: stumpy]
#2168064
10/04/16 11:10 PM
10/04/16 11:10 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Do you feel it in your hands or your butt? TMI TMI TMI TMI TMI
[Re: stumpy]
#2168070
10/04/16 11:15 PM
10/04/16 11:15 PM
RapidRobert
Do you feel it in your hands or your butt? My tire man asked me that when I was tracking down a vibration. turned out to be a front ujoint getting ready to let go (& it did)
[Re: 6T9Hemi]
#2168130
10/05/16 12:49 AM
10/05/16 12:49 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Has the rear suspension been updated or altered in any way? Incorrect pinion angle will cause a harmonic (pulsing) vibration if the u-joints are not properly phased.
[Re: stumpy]
#2168151
10/05/16 01:14 AM
10/05/16 01:14 AM
6T9Hemi
Elizabethtown, KY
Butt. It's like I'm sitting on top of the vibration. I already replaced U joints.
[Re: 6T9Hemi]
#2168195
10/05/16 03:37 AM
10/05/16 03:37 AM
RapidRobert
too much shaft end play causing not enough front yoke spline engagement in the trans (I had that causing a vibration for me once). worn extension housing bushing. worn trans mount. throwing out potentials.
[Re: RapidRobert]
#2168248
10/05/16 10:25 AM
10/05/16 10:25 AM
6T9Hemi
Elizabethtown, KY
What is the correct length for the driveshaft in a 69 GTS 340 auto?
[Re: stumpy]
#2168373
10/05/16 02:18 PM
10/05/16 02:18 PM
RapidRobert
What Stump said, you may be OK on that dimention as is. (have it loaded)
[Re: 6T9Hemi]
#2168427
10/05/16 03:45 PM
10/05/16 03:45 PM
6T9Hemi
Elizabethtown, KY
Is there any way that it could be the torque convertor balance? You are basically at a 1 to 1 ratio in drive. Could I be feeling an out of balance convertor in drive where the vibration is lost in first and second.
[Re: 6T9Hemi]
#2168486
10/05/16 05:20 PM
10/05/16 05:20 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
Convertor out of balance will be out of balance in all gears ... and in neutral .... moving or standing still ...
[Re: 6T9Hemi]
#2168567
10/05/16 07:30 PM
10/05/16 07:30 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
If it wasn't acting up before you had the "U" joints replaced, THAT is the first place to look and most likely culprit provided that nothing else was messed with.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: 6T9Hemi]
#2170267
10/08/16 01:35 PM
10/08/16 01:35 PM
Posts: 13,591 md
mopars4ever
md
