fuel pump size
#2167895
10/04/16 06:19 PM
10/04/16 06:19 PM
Posts: 1,015 Howell, Michigan
Hemidavey
Howell, Michigan
Need to buy a mechanical fuel pump for a big block, makes 439 HP on dyno at 5500 rpm. should I get an 80, 110 or 130 GPH pump. Have -6 lines all the way. Going in a steet/strip car. Thank you for advice
Re: fuel pump size
[Re: StealthWedge67]
#2168228
10/05/16 09:13 AM
10/05/16 09:13 AM
Posts: 4,672 Wichita
GY3
Wichita
I use the Carter street/strip pump sold by Mancini Racing. It's not as much psi as the one above (5-6 IIRC). I also used 5/16 line to the pump and 3/8 from pump to carb. Runs 11.19's @ 121mph in 3520 lbs.
