Duster with B-1 pictures wanted. #216731
02/07/09 04:15 PM
02/07/09 04:15 PM
Indy
joshking440 Offline OP
Lunch is on me!
Lunch is on me!
Indy
I have not been able to set my engine in the car yet, and I am afraid that with the blow thru hat on top of the tall b-1 intake that my 4" cowl hood will not clear... I was wondering if anyone has pictures of Dusters with Original B1 heads so I can figure out how high the hat will be.
Re: Duster with B-1 pictures wanted. [Re: joshking440] #216732
02/08/09 11:10 AM
02/08/09 11:10 AM
Toronto Ontario, Can
Glen440 Offline
Glen440  Offline
You'll be real close, I have a 6" cowl hood but it does not really measure that high and I put it from the bottom side so its closer to 5". I can run a big aircleaner under the hood still. I do have some pics of when I was test fitting the engine before it was built. This is a low deck 511.
87 dakota 6.1 hemi
Re: Duster with B-1 pictures wanted. [Re: Glen440] #216733
02/08/09 11:13 AM
02/08/09 11:13 AM
Glen440 Offline
Glen440  Offline
another
87 dakota 6.1 hemi
Re: Duster with B-1 pictures wanted. [Re: Glen440] #216734
02/08/09 11:22 AM
02/08/09 11:22 AM
Glen440 Offline
Glen440  Offline
cowl hood
87 dakota 6.1 hemi
Re: Duster with B-1 pictures wanted. [Re: Glen440] #216735
02/08/09 12:00 PM
02/08/09 12:00 PM
Glen440 Offline
Glen440  Offline
The car already had an engine plate when I bought it. I lowered it 1/4" for header clearance. I stuffed 2" TTI under chassis headers in the car because I had them from when it had eddy heads. I have lowered the K member 1/2". I built my own oil pan for ground clearance. The car is apart at the moment, will be going back together as soon as the snow clears abit.
It uses the passenger side spool mount to hold engine from moving.
87 dakota 6.1 hemi
Re: Duster with B-1 pictures wanted. [Re: Glen440] #216736
02/08/09 12:02 PM
02/08/09 12:02 PM
Glen440 Offline
Glen440  Offline
2
87 dakota 6.1 hemi
Re: Duster with B-1 pictures wanted. [Re: Glen440] #216737
02/08/09 12:09 PM
02/08/09 12:09 PM
Glen440 Offline
Glen440  Offline
oil pan
87 dakota 6.1 hemi
Re: Duster with B-1 pictures wanted. [Re: Glen440] #216738
02/08/09 12:15 PM
02/08/09 12:15 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
Are you going to run fuel injection? I see the bungs welded in.
How did you lower the K Member?
Re: Duster with B-1 pictures wanted. [Re: joshking440] #216739
02/08/09 12:19 PM
02/08/09 12:19 PM
Glen440 Offline
Glen440  Offline
Those are for nitrous, The intake had a fogger.
I put 1/2" spacers between the frame and the K member to lower it. I did that because the TTI headers hit the pitman arm when I had eddy heads.
87 dakota 6.1 hemi
