Is there such a thing as a leak free rear main seal mopar? #2167164
10/03/16 05:35 PM
10/03/16 05:35 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
Is it possible to have a mopar engine, be it small block or big block, with a leak free rear main seal?
being 2 piece seals, whenever I build an engine they always leak some.
Ive had some engines that leak very little, like I can see just a drop running down the oil pan....
but on some others I can see them leaving a small puddle whenever they get parked for a few weeks on a given spot.
IS THERE ANY WAY TO ACHIEVE A ZERO LEAK REAR MAIN SEAL ON THESE OLD MOPARS?????
Re: Is there such a thing as a leak free rear main seal mopar? [Re: domingo] #2167192
10/03/16 06:16 PM
10/03/16 06:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
popcorn
Re: Is there such a thing as a leak free rear main seal mopar? [Re: domingo] #2167213
10/03/16 06:42 PM
10/03/16 06:42 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have managed to have my small blocks leak just about everywhere else but with rear main seals I have been good, no leaks.
68 Barracuda Formula S 340
Re: Is there such a thing as a leak free rear main seal mopar? [Re: domingo] #2167217
10/03/16 06:49 PM
10/03/16 06:49 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Yep easy fix, it's called a vac pump. As soon as my engine starts it's under vacuum. 5" @ idle & 10" at full noise. No leaks on my engine since I installed one of these pieces n we even go faster with it too.
Re: Is there such a thing as a leak free rear main seal mopar? [Re: Bad340fish] #2167226
10/03/16 07:00 PM
10/03/16 07:00 PM
birdtracker Offline
birdtracker  Offline
on big blocks I wipe a small thin layer of " the right stuff" between the 2 lip pieces and between the block and the small sticks. I usually take my finger and spread it out and seal it up. Birdtracker
Re: Is there such a thing as a leak free rear main seal mopar? [Re: birdtracker] #2167280
10/03/16 08:48 PM
10/03/16 08:48 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
The answer is yes and it would be a 440 inch small block. 👌
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Is there such a thing as a leak free rear main seal mopar? [Re: domingo] #2167305
10/03/16 09:07 PM
10/03/16 09:07 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Yes. none of my 3 leak a drop.
Doug
Re: Is there such a thing as a leak free rear main seal mopar? [Re: domingo] #2167317
10/03/16 09:28 PM
10/03/16 09:28 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
ive had no luck then.
OK to those who claim that they build engines with perfectly leak free rear main seals....spill the beans....how do u guys do it.
Re: Is there such a thing as a leak free rear main seal mopar? [Re: domingo] #2167329
10/03/16 09:52 PM
10/03/16 09:52 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I have never had one leak there.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Is there such a thing as a leak free rear main seal mopar? [Re: D-50] #2167357
10/03/16 10:23 PM
10/03/16 10:23 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Mine is dry with Superformance main seal and Mancini billet retainer. Greg has explained many times on here about how to install a rear main without leaking. I install mine on a slight offset and make sure the retainer is centered in the saddle.
I opened up the holes slightly so when I slid it into place it was centered around the journal. Just make sure your pan is seated on the rear pan rail and not raised up on the studs.
I once thought my rear main was leaking but it was the pan and windage tray raised off the rear pan rail by the ARP studs.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Is there such a thing as a leak free rear main seal mopar? [Re: domingo] #2167362
10/03/16 10:26 PM
10/03/16 10:26 PM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
no leak here, used "the right stuff" in seal lips and side seals.....use a quality grease or moly lube on the seal itself to prevent it from burning up on start up
Re: Is there such a thing as a leak free rear main seal mopar? [Re: dvw] #2167376
10/03/16 10:51 PM
10/03/16 10:51 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Doug
Ditto.
Mine doesn't leak a drop.
I put the crank seals in slightly offset, put some oil in the crank first to keep it lubed and use a thin bead of Permatex Ultra Black on the inside where the cap meets the block and on the tips of the side seals.
Well over 2500 miles and lots of dragstrip passes.
'63 Dodge 330
11.19 @ 121 mph
Re: Is there such a thing as a leak free rear main seal mopar? [Re: domingo] #2167392
10/03/16 11:03 PM
10/03/16 11:03 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Mine only leak under boost lol
Re: Is there such a thing as a leak free rear main seal mopar? [Re: domingo] #2167409
10/03/16 11:30 PM
10/03/16 11:30 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Mancini Billet Retainer
Make sure block sides and top where Retainer makes contact is completely clean , and oil free
I used acetone to clean . Same with retainer , oil free where it contacts bock top and sides
Clock the parting line on the seal halves at 12 and 6 - Obviously make sure seal lips are oriented correctly and a little oil on both seal halves to help slide them both around top of crank meeting at 12
Slide the retainer dry over the two studs that Mancini supplies to evenly center both seal halves on the bottom of crank at 6
Even with the Mancini Billet Retainer I used a little Black RTV down the sides in between the o-rings and a dab on top where the o-rings slide in the holes
Double check block making sure it's still clean and oil free
Slide the retainer back again over the studs making sure the o-rings on both sides start evenly and firmly press the retainer in place over the centered seal halves - The rtv with the o-rings will almost act like a lubricant helping you slide the retainer in place against the sides of block
Clean off the excess black rtv
Remove studs making sure the retainer stays centered
Install bolts and torque in place
Zero rtv on any part of the actual seals themselves
Allow 24 hours to dry
Did my 383 this way and a friends brand new rebuilt 383 stroker motor that he had two shops attempt to seal with zero luck
Zero Drips So Far On Both
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Is there such a thing as a leak free rear main seal mopar? [Re: fourgearsavoy] #2167538
10/04/16 06:38 AM
10/04/16 06:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Gus beer
Yea I liked the idea of drilling the retainer holes a bit larger so you know the retainer and seal will center on the crank journal as I also do that and have had no seal leaks on my 493 thats been in the car since 2011. Ron
Re: Is there such a thing as a leak free rear main seal mopar? [Re: domingo] #2167630
10/04/16 11:50 AM
10/04/16 11:50 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
This has been discussed here in detail very recently. It's all about how you install it. Personally, I have never had one leak. Do a search and I am sure the threads will come up
Re: Is there such a thing as a leak free rear main seal mopar? [Re: domingo] #2167686
10/04/16 01:20 PM
10/04/16 01:20 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
do you guys think that the rear main seal can be changed on a big block without removing the crank?
Re: Is there such a thing as a leak free rear main seal mopar? [Re: domingo] #2167969
10/04/16 08:03 PM
10/04/16 08:03 PM
IN
ahy Offline
ahy  Offline
IN
Yes... the seal can be changed w/o removing the crank in chassis if necessary. Drop the pan and drop the retainer. Maybe loosen the main caps a little to let the crank drop slightly. Then work the top part of the seal in place. I did it to change a seal with significant leak installed by an engine builder.
It leaked significantly less after this service... but not completely dry either.
Re: Is there such a thing as a leak free rear main seal mopar? [Re: domingo] #2168091
10/04/16 11:38 PM
10/04/16 11:38 PM
Cab_Burge Online work
Cab_Burge  Online Work
Hi!
Absolutely up
As already pointed out it can be done with minimal effort, use the proepr parts and install them properly and use the correct preventive measures to seal the seal holder up so you end up with a leak free motor from the rear main seal up scope
Re: Is there such a thing as a leak free rear main seal mopar? [Re: domingo] #2168900
10/06/16 11:53 AM
10/06/16 11:53 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Once I apply Nitrous Oxide, mine start leaking.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
