HELP!!! Durango No Start #216722
02/07/09 03:51 PM
02/07/09 03:51 PM
Peoria, AZ
P
PIPES Offline OP
PIPES  Offline OP
P
Peoria, AZ
I have a 2000 Durango with a 360. I had it running yesterday, checking fluids and what-not. The truck started from cold (about 30*) and ran for about 5 minutes then just died like someone turned off the key. I can't get it to start, got spark and 50lbs of fuel pressure while cranking. Compression is 130 or so.
One thing I did notice was, when checking spark the plugs had an orange spark rather than the normal blue (weak?).
I ran the scanner and it has no codes logged.
WHY??? Won't it start???
80 Aspen R/T
Eddy headed 408
New Best 11.83 @ 112
Gettin' quicker
Re: HELP!!! Durango No Start [Re: PIPES] #216723
02/07/09 04:52 PM
02/07/09 04:52 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If the spark is not a nice "snapping" type, I'd suspect coil, as often as those fail lately. Just a thought.
Re: HELP!!! Durango No Start [Re: PIPES] #216724
02/07/09 06:56 PM
02/07/09 06:56 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
Do the plugs look wet? If not, spray a little starting fluid down the throat and see if it'll fire.
Re: HELP!!! Durango No Start [Re: FuryUs] #216725
02/07/09 07:29 PM
02/07/09 07:29 PM
Peoria, AZ
P
PIPES Offline OP
PIPES  Offline OP
P
Peoria, AZ
Plugs look fine. Tried some ether just to see if it was a fuel problem, nothing.
Can a coil get weak? I always thought they worked or didn't??? Could be wrong, wouldn't be the first time and gaurateed wouldn't be the last.
I was leaning toward PCM due to no fault codes...
80 Aspen R/T
Eddy headed 408
Gettin' quicker
Re: HELP!!! Durango No Start [Re: PIPES] #216726
02/07/09 10:36 PM
02/07/09 10:36 PM
Peoria, AZ
P
PIPES Offline OP
PIPES  Offline OP
P
Peoria, AZ
btt
80 Aspen R/T
Eddy headed 408
Gettin' quicker
Re: HELP!!! Durango No Start [Re: PIPES] #216727
02/08/09 01:34 PM
02/08/09 01:34 PM
Peoria, AZ
P
PIPES Offline OP
PIPES  Offline OP
P
Peoria, AZ
80 Aspen R/T
Eddy headed 408
Gettin' quicker
