Re: Is there such a thing as a leak free rear main seal mopar?
[Re: domingo]
#2167213
10/03/16 06:42 PM
10/03/16 06:42 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
I have managed to have my small blocks leak just about everywhere else but with rear main seals I have been good, no leaks.
68 Barracuda Formula S 340
[Re: birdtracker]
#2167280
10/03/16 08:48 PM
10/03/16 08:48 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
The answer is yes and it would be a 440 inch small block. 👌
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: domingo]
#2167329
10/03/16 09:52 PM
10/03/16 09:52 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I have never had one leak there.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#2167357
10/03/16 10:23 PM
10/03/16 10:23 PM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
Mine is dry with Superformance main seal and Mancini billet retainer. Greg has explained many times on here about how to install a rear main without leaking. I install mine on a slight offset and make sure the retainer is centered in the saddle. I opened up the holes slightly so when I slid it into place it was centered around the journal. Just make sure your pan is seated on the rear pan rail and not raised up on the studs. I once thought my rear main was leaking but it was the pan and windage tray raised off the rear pan rail by the ARP studs. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: dvw]
#2167376
10/03/16 10:51 PM
10/03/16 10:51 PM
Posts: 4,672 Wichita
GY3
Wichita
Yes. none of my 3 leak a drop. Doug Ditto. Mine doesn't leak a drop. I put the crank seals in slightly offset, put some oil in the crank first to keep it lubed and use a thin bead of Permatex Ultra Black on the inside where the cap meets the block and on the tips of the side seals. Well over 2500 miles and lots of dragstrip passes.
[Re: domingo]
#2167409
10/03/16 11:30 PM
10/03/16 11:30 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Mancini Billet Retainer
Make sure block sides and top where Retainer makes contact is completely clean , and oil free I used acetone to clean . Same with retainer , oil free where it contacts bock top and sides
Clock the parting line on the seal halves at 12 and 6 - Obviously make sure seal lips are oriented correctly and a little oil on both seal halves to help slide them both around top of crank meeting at 12
Slide the retainer dry over the two studs that Mancini supplies to evenly center both seal halves on the bottom of crank at 6
Even with the Mancini Billet Retainer I used a little Black RTV down the sides in between the o-rings and a dab on top where the o-rings slide in the holes
Double check block making sure it's still clean and oil free
Slide the retainer back again over the studs making sure the o-rings on both sides start evenly and firmly press the retainer in place over the centered seal halves - The rtv with the o-rings will almost act like a lubricant helping you slide the retainer in place against the sides of block
Clean off the excess black rtv
Remove studs making sure the retainer stays centered
Install bolts and torque in place
Zero rtv on any part of the actual seals themselves
Allow 24 hours to dry
Did my 383 this way and a friends brand new rebuilt 383 stroker motor that he had two shops attempt to seal with zero luck
Zero Drips So Far On Both
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: fourgearsavoy]
#2167538
10/04/16 06:38 AM
10/04/16 06:38 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Mine is dry with Superformance main seal and Mancini billet retainer. Greg has explained many times on here about how to install a rear main without leaking. I install mine on a slight offset and make sure the retainer is centered in the saddle. I opened up the holes slightly so when I slid it into place it was centered around the journal. Just make sure your pan is seated on the rear pan rail and not raised up on the studs. I once thought my rear main was leaking but it was the pan and windage tray raised off the rear pan rail by the ARP studs. Gus Yea I liked the idea of drilling the retainer holes a bit larger so you know the retainer and seal will center on the crank journal as I also do that and have had no seal leaks on my 493 thats been in the car since 2011. Ron
[Re: domingo]
#2167630
10/04/16 11:50 AM
10/04/16 11:50 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
ive had no luck then.
OK to those who claim that they build engines with perfectly leak free rear main seals....spill the beans....how do u guys do it. This has been discussed here in detail very recently. It's all about how you install it. Personally, I have never had one leak. Do a search and I am sure the threads will come up
[Re: domingo]
#2168091
10/04/16 11:38 PM
10/04/16 11:38 PM
Posts: 43,163 Bend,OR USA
Cab_Burge
Hi!
Is it possible to have a mopar engine, be it small block or big block, with a leak free rear main seal?
IS THERE ANY WAY TO ACHIEVE A ZERO LEAK REAR MAIN SEAL ON THESE OLD MOPARS????? Absolutely As already pointed out it can be done with minimal effort, use the proepr parts and install them properly and use the correct preventive measures to seal the seal holder up so you end up with a leak free motor from the rear main seal
[Re: domingo]
#2168900
10/06/16 11:53 AM
10/06/16 11:53 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Once I apply Nitrous Oxide, mine start leaking.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
