Re: Oil consumption in 2001 Dodge 4.7 engineI have
[Re: Citation_SP]
#2167100
10/03/16 03:30 PM
10/03/16 03:30 PM
dogdays
One possible answer is that with use the oil's viscosity index additives are shearing down, resulting in oil that has less than stock viscosity at operating temperatures.
This happens a lot more with petroleum oils as they require much more of the VI improver to flatten the viscosity x temperature curve.
A good synthetic might help this issue.
A way to check would be an oil test.
R.
[Re: Citation_SP]
#2167200
10/03/16 06:28 PM
10/03/16 06:28 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
My 02 quad cab with 4.7 called for 10w30 oil. After 9000 miles I switched to 15w40.Ran it that way until I traded it in with 205K on it. It was just then starting to use about a quart between oil changes... 4-5000 miles.
