Fellow Moparts Brothers- Please help me decide: #2166512
10/02/16 04:04 PM
10/02/16 04:04 PM
USA
hudsonhornet7x Offline OP
USA
The next project I have coming up will be a 70 Bee.
The car will be a street/ strip deal and will have a 727 with a Dana 60
The car will be a normal weight for a B body of that year, with a roll bar added.
I have no current E.T. Goals, just want to build a fun car.
I have 3 choices for engines in the shed, please complete the poll and maybe a brief explanation of why I should build one over the other. Thanks! HH
B Body Engine Poll
single choice
Votes accepted starting: 10/02/16 04:01 PM
Re: Fellow Moparts Brothers- Please help me decide: [Re: hudsonhornet7x] #2166537
10/02/16 04:43 PM
10/02/16 04:43 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Street strip car, 6.4 hemi.
Reason power vs drivability will be better.
"Just a Bracket car dressed up like a streetcar"
Re: Fellow Moparts Brothers- Please help me decide: [Re: hudsonhornet7x] #2166543
10/02/16 04:50 PM
10/02/16 04:50 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Whichever makes the most torque, not knowing if a turbo's in the Gen3 plan, or the gear/tire in a heavy street car. Low-decks are easier to service than RBs, as well as their other advantages.
The car I've been building in my head for some time would look like a stock 383 '68 Road Runner, but would be as light as possible with a 500"+ low deck.
Re: Fellow Moparts Brothers- Please help me decide: [Re: hudsonhornet7x] #2166571
10/02/16 05:33 PM
10/02/16 05:33 PM
USA
USA
The gen III would be naturally aspirated. Looking for big torque. AndyF's builds also have me wanting something like a 505.
I am afraid the gen III will seem so soft down low compared to a stroker.
Re: Fellow Moparts Brothers- Please help me decide: [Re: hudsonhornet7x] #2166659
10/02/16 08:39 PM
10/02/16 08:39 PM
I've made more HP and torque on all of my pump gas low deck 400 block stroker motors that I did with similar C.I. gen two 426 street hemiroid motors with similar carbs confused
I had to learned to trust the results(track and engine dyno tests) of these build and I now concentrate on getting the best heads I can get to start with and go from there up twocents
BTW, I like and use 4.250 and 4.300 stroke cranks with 2.200 rod journals on these builds with the longest BB Chevy type rods I can get away with, 6.700 or 6.800 with .990 pins and a custom piston order for that specific build thumbs
My first 511 C.I. 400 block stroker made 612 HP at 5500 RPM and 644 Ft lbs at 4500 RPM with a mild set of 906 heads with big valves(2.14 and 1.81 ex.) and a low deck sixpak setup boogie
That same motor with a .050 longer stroke crank, went from 4.25 to 4.300 to increase the comp. ratio from 9.25 to 1 to 10.3 to 1, ended making 775 HP at 7500 RPM with a ported set of 440-1 with 2.250 intakes on Oregon pump swill at 4300 ft elevation on a calibrated DTS engine dyno with a stock 400-3 intake and 1050 Holley Dominator carbdevil shruggy
Re: Fellow Moparts Brothers- Please help me decide: [Re: hudsonhornet7x] #2166676
10/02/16 09:16 PM
10/02/16 09:16 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I voted 6.4 but it was tough. Would you be stroking the 6.4 or just run it as a takeout? Keeping VVT? 6.4 is a great engine, awesome flowing heads and a stout block, BUT, a 400 stroker (4.25" arm) would be a very nice street package. Sure, the Apaches flow 330-340 ish stock, but you have to twist 392" pretty hard to take full advantage of it. A 500" BB with some street type heads (trickflows, edelbrocks, etc) would make a mountain of torque which is nice for a street car.
Re: Fellow Moparts Brothers- Please help me decide: [Re: hudsonhornet7x] #2166684
10/02/16 09:27 PM
10/02/16 09:27 PM
gregsdart Offline
gregsdart  Offline
I voted 6.4 mainly for great drivability with the right o.d. trans and the right rear gear.If you want killer instant insane low speed torque , top that 6.4 with a twin screw blower and hang on. It will need forged pistons and good rods.
Re: Fellow Moparts Brothers- Please help me decide: [Re: gregsdart] #2166693
10/02/16 09:43 PM
10/02/16 09:43 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Hemi.....You either have one or you want one.
Re: Fellow Moparts Brothers- Please help me decide: [Re: hudsonhornet7x] #2166697
10/02/16 09:51 PM
10/02/16 09:51 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I chose the Gen III but with a couple of conditions.
Keep the EFI and at a minimum run a 46RH trans if you don't/can't keep all the boxes it takes to run the engine and a NAG1.
A 70 Bee should scale out at least few hundred pounds lighter than an LX so it should be sporty to drive plus economical.
This choice ignores the challenges of swapping in an engine that doesn't belong ie mounts, accessories, headers etc.
My second choice would be a 4.25" stroke 400 with CNC Stealths or less stealthy Trickflows dressed up as a 383 stock valve covers and all. Hydraulic flat tappet and use the money saved from the roller towards a FiTech or similar EFI. 727 with 3.23 gears max or whatever OD option that suits you that will give you 3.91/4.10 type launch and 3.00ish cruise.
No way the 400 stroker will be as fuel efficient as a Gen3 but it won't be boring. It will also bolt in with little to no grief depending on your trans choice.
Kevin
Re: Fellow Moparts Brothers- Please help me decide: [Re: hudsonhornet7x] #2166789
10/03/16 12:15 AM
10/03/16 12:15 AM
USA
USA
Thank you all for the replies. If I do go with the 6.4, I would be putting in forged rods and pistons. A good note to remember is that a B body will be lighter than an LX. Funny to think that a B body will be the lighter weight car. LOL.
I have never experienced a big block stroker, but I can imagine that it is exhilarating. For those with experience, will I be satisfied with a 6.4 compared to a stroker? I know the rear gears and setup will be quite different from each other.
Re: Fellow Moparts Brothers- Please help me decide: [Re: hudsonhornet7x] #2166856
10/03/16 02:00 AM
10/03/16 02:00 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The 6.4 has more potential apples to apples period. Plus they are very easy to crack 600hp on pump puke. The difference is they also do it with STOCK valvetrain and juice lifters 0 maintenance. No $1000 lifters, $1000 rockers or $2-3K to get GOOD heads needed. THAT is why I made the change.
Mopar to the bone!!!
Re: Fellow Moparts Brothers- Please help me decide: [Re: hudsonhornet7x] #2166869
10/03/16 03:07 AM
10/03/16 03:07 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Prefer the K.I.S.S. principle myself. Low deck stroker, plenty of options for parts.
Re: Fellow Moparts Brothers- Please help me decide: [Re: hudsonhornet7x] #2166953
10/03/16 12:04 PM
10/03/16 12:04 PM
USA
USA
Guys I really appreciate the information here. You all have built way more than I ever will and hearing about some of your combinations is cool. I am still undecided, but all the info is helping.
Re: Fellow Moparts Brothers- Please help me decide: [Re: hudsonhornet7x] #2166959
10/03/16 12:08 PM
10/03/16 12:08 PM
USA
USA
72 Swinger, If I remember you had a big block before you did the gen III. Does the new hemi pull as hard?
Re: Fellow Moparts Brothers- Please help me decide: [Re: Dragula] #2166962
10/03/16 12:11 PM
10/03/16 12:11 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
That would be 2nd gen!
And one more thing,,,,,BOOST is a wonderfull thing!!!!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Fellow Moparts Brothers- Please help me decide: [Re: hudsonhornet7x] #2166982
10/03/16 12:45 PM
10/03/16 12:45 PM
USA
USA
2nd gen would be cool, but I don't have a block. Anyone have a good one for sale lol!
Re: Fellow Moparts Brothers- Please help me decide: [Re: hudsonhornet7x] #2167048
10/03/16 02:27 PM
10/03/16 02:27 PM
dogdays Offline
dogdays  Offline
I said GIII because the B/RB strokers have been done to death.
Torque-shy engines need gears. For that, the 727 is not a good choice.
If you are dead set on a 727 I switch my vote to 4.25 stroke 400 block with the Trickflow heads.
R.
Re: Fellow Moparts Brothers- Please help me decide: [Re: hudsonhornet7x] #2167061
10/03/16 02:50 PM
10/03/16 02:50 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Either the 400 or 440 with a 4.25 crank.
I'd probably do the 440 myself...... The header choice situation is slightly better along with main bearing choices.
Re: Fellow Moparts Brothers- Please help me decide: [Re: Al_Alguire] #2167405
10/03/16 11:27 PM
10/03/16 11:27 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
When I built my Duster I literally lost sleep over this very subject, which engine combination to go with.
I planned on a Gen3 Hemi but all the prices were adding up too fast, then I decided on a stroked small block but I ran across a super stock drag racer selling a brand new 500" low deck(400)stroker kit and I am glad I went that route since I wanted to run a 727, 3.23 gears, and a fairly tight converter along 10.5 to 1 pump gas compression and a mild solid cam.
Header fitment is a big issue with the big block A-bodies and working on the engine and trans and starter can be frustrating but other than that it is such an awesome combo for the street. I cruise my Duster every sunny day, never runs hot even on a 95 degree day, gets decent gas mileage and it will literally do a smokey burnout at 50 mph! Very fun combo.
Re: Fellow Moparts Brothers- Please help me decide: [Re: hudsonhornet7x] #2167415
10/03/16 11:35 PM
10/03/16 11:35 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
smile
