Re: Better valve stem seals??
[Re: sg66mopar]
#2166837
10/03/16 01:29 AM
10/03/16 01:29 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The seals you have are pretty standard fare for triple springs.
The options I see are, cut down the guide boss so you can use a seal that has the rubber inside the jacket, but will still have an OD small enough to fit inside the triple springs.
Get another set of what you're using now and put a little silicone on the OD of the guide before installing them.
Come up with better oil control to the top end. A .020 hole in each pushrod will allow for more than enough oil to get up top. Even .015 is plenty big.
[Re: sg66mopar]
#2166960
10/03/16 12:10 PM
10/03/16 12:10 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I had the same problem with the comp seals. I used a cutter from comp on the guides for the .530 seals and the seals did not fit tight, they could easily be removed. As you would guess this didn't work at all and since I do not run a triple spring I was able to go back to the viton seals with a metal jacket and all is well.
I had the same problem with the metal seals on my edelbrock heads, but on the edelbrock heads the seals fit the guide tight and were not easy to get off. My heads came from the port shop with these seals and after chasing down a smoking problem I changed them as a last resort and that was the fix.
68 Barracuda Formula S 340
[Re: sg66mopar]
#2167134
10/03/16 04:37 PM
10/03/16 04:37 PM
Posts: 452 new york usa
pattyboy 572
new york usa
I read the other day that member DVW installed roll pins @ the lifter end and restricted his oil flow without purchasing new push rods,just a thought
