Re: Rearend widths
[Re: flatiron]
#216470
02/07/09 07:54 PM
02/07/09 07:54 PM
Posts: 4,747 Florida
BDW
Thank you so I'll take it the chart is wrong and the measurement's typed in are correct
What list / chart are you referring to?
Re: Rearend widths
[Re: BDW]
#216473
02/07/09 08:15 PM
02/07/09 08:15 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Sorry to be a pain, but I don't see any B-rearend listed as 51.4.
I'm in the process of putting a Dana in my Challenger, are the E-body numbers correct?
You need to scroll down to the chart.. It is incorrect, not the info above it...
Re: Rearend widths
[Re: BDW]
#216475
02/07/09 09:28 PM
02/07/09 09:28 PM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
Dana 60 rearend specs:
'66 B-body 54 1/4" housing, 59 3/8" axle flange to flange, 44" perch 23 spline power-lock sure-grip, 1330 U-bolt yoke
'67 B-body 54 1/4" housing, 59 3/8" axle flange to flange, 44" perch 23 spline power-lock sure-grip, 1330 strap yoke
'68-'69 B-body 54 15/16" housing, 60 1/16" axle flange to flange, 44" perch, 23 spline power-lock sure-grip, 7290 yoke
'70 B-body 54 15/16" housing, 60 1/16" axle flange to flange, 44" perch, 35 spline power-lock sure-grip, 7290 yoke
'71-'72 B-body 57 7/8" housing, 63" axle flange to flange, 47.3" perch, 35 spline track-lock sure-grip, 7290 yoke
'70 E-body 56 31/64" housing, 61 5/8" axle flange to flange, 46" perch, 35 spline power-lock sure-grip, 7290 yoke
'71 E-body 56 31/64" housing, 61 5/8" axle flange to flange, 46" perch, 35 spline track-lock sure-grip, 7290 yoke
**Driver's side housing tube and axle is 1 3/8" longer on all Dana 60 passenger car assemblies.
**B-body pinion measures 4 degrees up when perches are level.
**E-body pinion measures 7 degrees up when perches are level.
Re: Rearend widths
[Re: DoctorDiff]
#216476
02/07/09 10:10 PM
02/07/09 10:10 PM
BDW
Thanks Dr.
May seem like a silly question, but are the perches same distance from flange end on both sides?
For the e-body, I should weld the perch 5 1/4 in?
There are no perches on it now, and I want to make sure of the correct spot.
Thx
