Re: SB Victor Update
[Re: sst404b]
#2164467
09/29/16 04:25 PM
09/29/16 04:25 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Sounds like it has easy 8's in it once sorted out.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: sst404b]
#2164711
09/29/16 10:01 PM
09/29/16 10:01 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Congrats, hope it continues to hold up.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#2164815
09/29/16 11:59 PM
09/29/16 11:59 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Great news hope you do well in 10.90. But let's see what she will run. All out
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: sst404b]
#2164936
09/30/16 04:08 AM
09/30/16 04:08 AM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Sounds like it is working good. Be interested to see where it ends up on the stop..
[Re: sst404b]
#2165323
09/30/16 07:12 PM
09/30/16 07:12 PM
Posts: 5,485 SoCal
Brian Hafliger
SoCal
The conditions in Shreveport were terrible and this was the first race with new setup.All things considered we think it ran pretty good. The forecast for Noble next week is looking good,highs in mid 70s and no rain. We expect it to run a little better. We run a 3 speed so our 10.90 tune is different than what the PG guys run.This thing is 100+ hp better than the W2 setup we had,that's why we've had to work mainly on the 10.90 part of our program. We believe it will run 8.80s 8.90s and 145 at 10.90 when sorted out. I plan to have a new cam ground and work the intake to put a 4500 base carb on over the winter, this should liven things up.
Ray Buckner We'll be trying an Indy intake on our Victor heads...if we ever get a block! I would look into TD rockers when you change the cam... Brian
Brian Hafliger
[Re: sst404b]
#2165695
10/01/16 10:16 AM
10/01/16 10:16 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Thanks for the update, I am currently walking the fence between these heads and going gen III
68 Barracuda Formula S 340
