D100,150,200,250? What's the difference? #2159365
09/22/16 01:04 PM
09/22/16 01:04 PM
Manitoba, Canada
DaytonaTurbo Offline OP
Manitoba, Canada
What's the difference between a D100 and a D150? Or a D200 vs a D250? I get half ton vs 3/4 ton but what does having or not having the extra 50 mean?
Re: D100,150,200,250? What's the difference? [Re: DaytonaTurbo] #2159437
09/22/16 02:29 PM
09/22/16 02:29 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I do believe they came out in around 77, they have a heavier GVWR in order to meet heavy duty US federal emissions ratings.
Re: D100,150,200,250? What's the difference? [Re: DaytonaTurbo] #2159526
09/22/16 04:54 PM
09/22/16 04:54 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
May have been more related to trim levels, or it seemed that way on my 78 thru later eighties etc.
Re: D100,150,200,250? What's the difference? [Re: DaytonaTurbo] #2159541
09/22/16 05:23 PM
09/22/16 05:23 PM
God's Country Maryland
GODSCOUNTRY340 Offline
When the EPA handed out their rules (restrictions) for the D100 and W100, Chrysler started calling the trucks D150 and W150 to avoid the EPA regulations for a while so they had more time to meet their rules.
Re: D100,150,200,250? What's the difference? [Re: DaytonaTurbo] #2159738
09/22/16 10:39 PM
09/22/16 10:39 PM
places
79powerwagon Offline
places
D 100/150 trucks are 1/2 ton 2wd.
W 100/150 trucks are 1/2 ton 4x4.
D200/250 are 3/4 ton 2x4
W200/250 are 3/4 ton 4x4
and so on.
The difference between a 100 and 150 is simply the year of manufacture. Ford became an F150, Dodge followed suit. GM jumped from 10 to 1500, and Dodge followed that (later).
Re: D100,150,200,250? What's the difference? [Re: DaytonaTurbo] #2159759
09/22/16 11:14 PM
09/22/16 11:14 PM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
My 75 W100 was the heavier version, technically it was a W150. It had a 6100 gvw, so that way it didn't have to have any emissions equipment on it. Mine had no egr valve, sealed fuel system, etc.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: D100,150,200,250? What's the difference? [Re: 79powerwagon] #2159961
09/23/16 11:05 AM
09/23/16 11:05 AM
Des Moines IA
Soopernaut Online content
Soopernaut  Online Content
Des Moines IA
Many years they made both the 100 and 150.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: D100,150,200,250? What's the difference? [Re: Soopernaut] #2160089
09/23/16 01:50 PM
09/23/16 01:50 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
This is true. I have a '82 D150 and a '84 D100.
The difference is GVW rating.
In the mid '70s, catalytic convertors were required on trucks if they were under a certain GVW. Bumping the GVW up on a D100 to a new D150 model exempted the need for a CC.
Eventually the CC requirement GVW was raised over the years. The last year the D150 was exempt was 1978, '79 150s had CCs. The D250 and 350 exemption went into the '80s. I had a '84 D350 that came without CCs.
Re: D100,150,200,250? What's the difference? [Re: DaytonaTurbo] #2160144
09/23/16 02:48 PM
09/23/16 02:48 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Had an 89 w350, factory non cat. Dual smog pumps though.
Angry white pureblood male
Re: D100,150,200,250? What's the difference? [Re: 79powerwagon] #2161323
09/25/16 12:50 PM
09/25/16 12:50 PM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
ITS 4X2---- a 2x4 IS A PIECE OF LUMBER
Re: D100,150,200,250? What's the difference? [Re: DaytonaTurbo] #2163230
09/27/16 11:17 PM
09/27/16 11:17 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
In the beginning the 00 were the base rating/component trucks, the 50 were the HD version of that series meaning Bigger Alt, Trans, Fuel tank, Radiator, Diff, tires and payload just to some of the upgrades. As the series number got bigger the upgrades also included frame construction (taller, thicker and even double walled)
eventually they dropped the 00 and just added HD packages. This was a manufacturing cost savings ( brochures, emblems ect...) and also led the less informed consumer assume all trucks were equal
and I just remembered here is the ratings "in the beginning"
D/W 100 = 1/4 ton
D/w150 = 1/2 ton
D/w200 = 3/4 ton
D/W 300 = 1 ton
The 250 and 350 badging didn't start till mid to late 70's
for example I owned a '74 D300 with a 10000lb GVW
and a 83 D350 with a 8750 GVW
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: D100,150,200,250? What's the difference? [Re: DaytonaTurbo] #2163738
09/28/16 04:10 PM
09/28/16 04:10 PM
Des Moines IA
Des Moines IA
The 1st year of the D150 was 1977. I had one with the 8 3/8 rear axle from the factory. There were D100s with the 9.25. The same transmission was available in both, fuel tank sizes were not dependent on truck weight, alternators were optional, the same spring capacities were available on the D100 and D150, tires and wheels were the same size, the frames were the same, etc.
From the brochure:
*All D100 models include Evaporative and Exhaust Emission Control System. All D150,D200 and D300 models include heavy-duty Exhaust Emission Control System.
Re: D100,150,200,250? What's the difference? [Re: 79powerwagon] #2164168
09/29/16 06:42 AM
09/29/16 06:42 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
and so on.
GM went from 10 to 15
Re: D100,150,200,250? What's the difference? [Re: Morty426] #2164551
09/29/16 06:26 PM
09/29/16 06:26 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
only the d-150 came with big block
Re: D100,150,200,250? What's the difference? [Re: DaytonaTurbo] #2164965
09/30/16 07:46 AM
09/30/16 07:46 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Not so sure about that. Buddy of mine had a 78 W300 with a 440. He ordered it new, kept it till he passed away about 7 years ago.
Always garage kept, wish I had it.
Re: D100,150,200,250? What's the difference? [Re: DaytonaTurbo] #2165929
10/01/16 03:21 PM
10/01/16 03:21 PM
Byron, NY
Byron, NY
I presume he meant the D100 couldn't be purchased with a BB but the rest could.
'60 Willys CJ5
Re: D100,150,200,250? What's the difference? [Re: DaytonaTurbo] #2174586
10/14/16 03:35 PM
10/14/16 03:35 PM
Sunny South
N
Noah Zarq Offline
Noah Zarq  Offline
N
Sunny South
I read somewhere that the 100 models were lightweight (as far as carrying and towing capacity) versions that were subject to stringent emissions (catalytic converters, etc) whereas the 150 models were considered a "heavy half-ton" and were not required to have as many emission controls. Additionally, the 150 models may have had a few goodies not available on the more basic 100 models.
My D100 was my grandfather's and it's as basic as they came; the only option it has is carpet. The D150s also had slant sixes as the base powerplant, but they must've had better springs or something because my D100 wallows like a hippo on a slip-n-slide when I tru to carry more than a couple sacks of fertilizer.
Re: D100,150,200,250? What's the difference? [Re: W.I.N. Racing] #2177495
10/18/16 03:17 AM
10/18/16 03:17 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
What years are you referring to?
I had a 67 D100 that had a 383 and have seen many Sweptlines so equipped.
Kevin
Re: D100,150,200,250? What's the difference? [Re: Twostick] #2177732
10/18/16 03:29 PM
10/18/16 03:29 PM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
My bad meant difference in 100 and150.and yes there was a special package 100 with 383 but couldn't get a 440.of course 3/4 ton and up could b had with big block
Re: D100,150,200,250? What's the difference? [Re: d-150] #2178529
10/19/16 01:21 PM
10/19/16 01:21 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If you mean a CSS, mine was just a custom cab D100. No CSS.
There is a 70 or 71 D100 local to me that is a 383/727 with A/C and power steering.
Kevin
