Restoring a steering column #216398
02/06/09 11:29 PM
02/06/09 11:29 PM
Louisiana
duckblind Offline OP
Louisiana
I just purchased a steering column for a floor shift 68 b body with power steering. How hard are the steering columns to take apart in order to paint. Does anyone know of any literature that breaks down how to rebuild a steering column?
Any info would be appreciated.
Thanks.
Re: Restoring a steering column [Re: duckblind] #216399
02/07/09 12:35 AM
02/07/09 12:35 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I have taken a few apart, Snap ring pliers scew drovers and a nut driver or 2 will do it the rebuild kit with the new shoes are avalible new at a dealer {like 4 bucks}but will have a red rubber cover instaed of black.
Most of the time the large pin does not need to be pressed out and changed just the shoes do.
snap rings and the smaller pin that holds the whole coupler on is the hardest part.
If you have a problem with the covers staying on there is a guy selling a part that keeps it from poping off.
If you need a blow up of it taken apart i can scan/copy a book and fax it to ya
This is the clamp guy I got 2 of them and they worked great
I sell a clamp that holds the steel cover on the top of the steering coupler at the base of the steering column. This will keep the cover from "hanging loose" on the column and it is a reproduction of an original Chrysler part that is no longer available. It will work on most rear wheel drive Mopars from 1967 thru 1993 pickups/vans. My page also has a service bulletin explaining the clamps use and additionl info about steering columns. www.mopar4sale.com
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Restoring a steering column [Re: 340SIX] #216400
02/07/09 10:40 AM
02/07/09 10:40 AM
None
71rm23 Offline
71rm23  Offline
None
340Six- Looked at the site you posted, couldn't find a link for the steering column. Can you clearify where it is? I'm interested in rebuilding my column as well or maybe just send it to Jules
Does anyone know where I can get the electrical parts inside of the column? For a '71 RR column shift BTW
Re: Restoring a steering column [Re: 71rm23] #216401
02/07/09 01:21 PM
02/07/09 01:21 PM
340SIX Offline
340SIX  Offline
Advace auto parts has the ignition switch cheaoer than the dealer does.
Re: Restoring a steering column [Re: 340SIX] #216402
02/07/09 08:37 PM
02/07/09 08:37 PM
None
71rm23 Offline
71rm23  Offline
None
Didn't know the dealer still carried them.
Re: Restoring a steering column [Re: 71rm23] #216403
02/08/09 07:13 PM
02/08/09 07:13 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
They are pricey at $120 or so but the 70-74 switches are still available.
Craig
