Has anyone had experience with installing a re manufactured, reprogrammed ECM and then immediately started getting new "check engine" codes that were not there before?
I got the unit pre-programmed from Napa to solve my "battery not charging issue", and the charging issue is resolved but now the codes appear but according to Napa it is not the problem.
![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
I don't really want to fight it.
Anyway, just curious if this is a common thing or not. The codes were not there before the change. The charging issue is fixed, btw.
eight
