Lunati 60342 compared to .509?
#2163860
09/28/16 07:50 PM
09/28/16 07:50 PM
Posts: 407 NE Indiana
momopar
NE Indiana
I have read (in other forums) that the .509 is bigger than the Lunati 60342 solid in 'real' duration.
That doesn't seem right?
I know the hydraulic does't see lash but 8-10 degrees more for the solid to match seems extreme.
Could someone please 'splain,,,,,,,,,,,,,,,,,,,,,,, please?
Re: Lunati 60342 compared to .509?
[Re: momopar]
#2164641
09/29/16 08:28 PM
09/29/16 08:28 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
3.23 gears
Talk about a mismatch.
You're building a high rpm engine and dog it out with those gears.
Years ago I built a .060 over 413 with the street hemi grind cam, much milder than either of your choices, same heads but not as much compression. It ran ok with 3.23's and a stick but it kicked butt when I put 4.10's in.
You need more gear and better heads if you really want to run a .557 cam.
[Re: momopar]
#2164959
09/30/16 07:07 AM
09/30/16 07:07 AM
momopar
NE Indiana
YUP!
Lunati actually advised the 60341, but,,,,,,,,,,,,,,,,,,,, politically incorrect is the way I seem to fly?
Used to have the old D.C. 'Hemi grind (472/280?) it was a bit too mild for my tastes. I have a spare 4.56 center section. Never been fond of running them low gears, sure it rips but running down the road they ain't much fun.
Thanks for the reality check, I know what I need,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, but I know what I want?
Damned Tim Allen syndrome.
[Re: momopar]
#2165015
09/30/16 11:35 AM
09/30/16 11:35 AM
Supercuda
About to go away
About to go away
up yours
I ran those 4.10's all over the place, including a trip from Memphis to San Diego.
Not sure why people bag on steeper gears on the highway, put in an OD if it's a big problem and have the best of both worlds I guess.
[Re: momopar]
#2167597
10/04/16 10:46 AM
10/04/16 10:46 AM
DaytonaTurbo
Manitoba, Canada
Me thinks the .509 is more raunchy than the .557?
Yes but unless you're going to a 4.10 rear gear it doesn't really matter in your case. I don't think you'll like anything more aggressive than the .528 with your rear gear. A 2" tire diameter change won't fix that.
[Re: momopar]
#2167757
10/04/16 03:19 PM
10/04/16 03:19 PM
Supercuda
About to go away
About to go away
up yours
He's building a 446, which I assume to be a bored 440, nonetheless a larger displacement engine, especially with a longer stroke will be more forgiving of larger cams.
Point is my 60 over 413 was 20 inches smaller, same stroke, than his 446. Your 493 was 47 inches larger and what's the stroke difference?
Personally, I think his bottom end will be soggy.
[Re: Twostick]
#2167931
10/04/16 06:51 PM
10/04/16 06:51 PM
momopar
NE Indiana
What exactly are you putting this cam in?
'69 Coronet R/T Factory Y2 yella, Rancharger, been sitting (inside)since the fall of '84. Surprisingly nice car, I be the third owner 79,000 mile ORIGINAL never been titled more than 25 miles from the dealer it was purchased at new! That holds true today. Yup I've been haulin' the old gal with me 32+ years and three wives later,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,' I still have it!
[Re: momopar]
#2168177
10/05/16 02:18 AM
10/05/16 02:18 AM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
I ran the 509 in my current 440 , it likes stall and gear plus compression. I started with a 4200 and 3.9 gears , ended with 5000 and 4.1 . I also tried that Lunati when I went sft , it was good but not noticeably better on the chassis dyno , though I never ran it at the track . Had a fabulous loud sound , even louder than the 509 . I also fitted the Lunati in a 510 stroker and another 440 both ran great with rump . The Lunati was great on the street . Surprisingly I also had the 509 in a 8:1 440 , but it also had the 4200 plus 3.9 gears though I also had 3.54 gears at 1 stage . I always run a 29" road tyre , 28" on the strip . The 509 also did a couple of interstate runs , 12hrs each way , no worries . With the tight lobe 509 there is no engine vacuum for brakes especially with a single plane intake .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: momopar]
#2168321
10/05/16 01:02 PM
10/05/16 01:02 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
One of my friends said it best about the 509 cam, "baddest cam at the drive in".
If you want something that really sounds tough, and is low effort and easy on parts, that's it.
But......... Anyone priced one of the 108lsa versions lately?(P4120237AE) Last I saw, the price reflected what I can only assume is FCA thinking, "we don't want to sell these anymore".
If I were to recommend an off the shelf grind that fits the same application criteria as the .528 cam, but would have a little rougher idle, I'd say the Hughes 4246.
For a real "street" cruiser though, I'd use something with less lift and smoother(slower) ramps that could be controlled with less spring. Something more like the 528, but on a tighter lsa to put a little more "pop" in the exhaust at idle. I haven't seen anything like that in a catalog, so it would likely have to be a custom.
[Re: momopar]
#2168580
10/05/16 07:58 PM
10/05/16 07:58 PM
fast68plymouth
So. Burlington, Vt.
If you left it up to me, you wouldn't get anything too wild for that build.
It would be milder than the 509 cam for sure.
[Re: momopar]
#2169496
10/07/16 09:36 AM
10/07/16 09:36 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
There was a 284/528 cam with a 106 lobe center, it was one of their circle track cams...picked one up several years ago.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
