Page 8 of 85 1 2 6 7 8 9 10 84 85
Re: paint job on a budget!? [Re: 6T6Cuda] #21630
01/30/06 02:01 PM
01/30/06 02:01 PM
toronto canada
69chargeryeehaa Offline
toronto canada
So you guys are using mineral sprits?
When I sprayed rustolem last summer, I thought it said to thin it with asatone (sp?)...
Is it different if you roll it vs. spraying? Or is mineral sprits better for this process?
Or am I just
RAR II
i've tried varsol, laquer thinner, but not acetone, i found mineral spirits work the best, i would think that acetone would "flash" the paint too quickly. mineral spirits seems to be the best and has alot of other uses like cleaning carbs, taking off overspray ect....
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21631
01/30/06 03:09 PM
01/30/06 03:09 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Does it work OK to mix up a batch of this mineral spirits and paint and then store it in a jar? So far I've been mixing each time to get the mixture right but I think I'll stick with 10-15% and put it in a jar if that would work, so I can have more consistent batches.
Re: paint job on a budget!? [Re: Exit1965] #21632
01/30/06 03:21 PM
01/30/06 03:21 PM
toronto canada
toronto canada
yes, thats fine, but u may have to add a bit more thinner like 2% when u use it next.
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21633
01/30/06 07:02 PM
01/30/06 07:02 PM
Gambrills, Md
mopork Offline
mopork  Offline
Gambrills, Md
YEEHAA thanks for all the good info
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21634
01/30/06 07:07 PM
01/30/06 07:07 PM
Missouri
P
petty43 Offline
petty43  Offline
P
Missouri
I was told to do this on my 46 ford frame by an "old timer". I already have a gallon of black. I think I'll try it on my 54 chevrolet truck fenders. It's a truck you know so I don't care how that much how it turns out.
Question?
Can you go right over the paint after some sanding and prep or do you need to go to metal and "bondo"?
1968 Satellite RR Copy Cat My Fleet
Re: paint job on a budget!? [Re: petty43] #21635
01/30/06 09:03 PM
01/30/06 09:03 PM
toronto canada
toronto canada
Question?
you can go right over anything, just make sure u scuff the old paint a bit.
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21636
01/30/06 10:08 PM
01/30/06 10:08 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Here is an Excel spreadsheet to calculate how much spirits to add for whatever % you want to end up with.
Hopefully we can learn what works best..
2354309-paintmixing.xls (2859 downloads)
Re: paint job on a budget!? [Re: Exit1965] #21637
01/30/06 10:38 PM
01/30/06 10:38 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Here it is after wetsanding coat #2 with 600.
Re: paint job on a budget!? [Re: Exit1965] #21638
01/30/06 10:38 PM
01/30/06 10:38 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
And here is the freshly applied 3rd coat. It's starting to look interesting!
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21639
01/31/06 01:33 AM
01/31/06 01:33 AM
Anonymous OP
Anonymous OP
I know that you mentioned having the paint tinted at the store, but what about mixing stock colors? For example, mixing some "Sunburst Yellow" with "Grass Green." (see http://www.rustoleum.com/product.asp?frm_product_id=18&SBL=1) Does this paint mix well, or do you think the different colors will stay separated in the mix?
Re: paint job on a budget!? #21640
01/31/06 10:53 AM
01/31/06 10:53 AM
toronto canada
toronto canada
i see no reason why it would'nt mix well
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21641
01/31/06 11:10 AM
01/31/06 11:10 AM
toronto canada
toronto canada
exit1965 - nice pics, as you can see it only gets better. i would have tested on a larger pannel, it's hard to just do a small area and take it thru the whole process, wait till you've got 6 coats on it and after the final wetsand and polish, you'll be very happy.
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21642
01/31/06 01:08 PM
01/31/06 01:08 PM
Oakland california, USA
Dart360sav Offline
super street
Dart360sav  Offline
super street
so do you think that home depot could mix me up some sublime green?
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21643
01/31/06 01:13 PM
01/31/06 01:13 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Thanks 69charger.
I wish I would have used a bigger test space also. to the left of the test area is what I used for practicing welding trim holes shut, so it's got lots of grinding needed if I want to use that area, but I just might to do more testing.
One thing I'd like to know is how you clean your roller after use? I have been washing it out with mineral spirits and water then using a paper towel to dry it, but I think some of the fibers from the paper towel are sticking to the roller and coming off in the paint! I'm not sure the best way to clean it off.
Oh well at least I'm figuring this out now without doing an actual car.
Re: paint job on a budget!? [Re: Exit1965] #21644
01/31/06 01:39 PM
01/31/06 01:39 PM
toronto canada
toronto canada
Thanks 69charger.
well if i'm using the roller again that day i put it in a plastic bag, take all the air out and load up the roller before i put it in the plastic bag, otherwise i just throw it out and use a new one if i'm painting the next day, they are only about $5 for 5 of them. oh and DON'T use water!!!
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21645
01/31/06 02:09 PM
01/31/06 02:09 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Great tips thanks!
Re: paint job on a budget!? [Re: Exit1965] #21646
02/02/06 10:43 PM
02/02/06 10:43 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Phew this thread got cold fast! I should probably have been done with all steps by now but life got in the way the last 2 days, so I just now have put the 4th coat on and now the color is completely covering what was under it. It's looking much more orange peely than previous coats but I'm not too worried since the next step is wetsanding, then 2 more coats, wetsanding and then polishing.
Hopefully by Sunday I'll have a final result, then I'll put the door outside and see how well it holds up..
Re: paint job on a budget!? [Re: Exit1965] #21647
02/02/06 10:51 PM
02/02/06 10:51 PM
toronto canada
toronto canada
ya i guess all of a sudden it was read by just about everyone!!! like a new girlfriend the excitment has gone.....
regarding your door expirement, there is something your doing wrong, i get virtually NO orange peal. maybe too thick? i dunno, the wetsanding just makes it perfect, i wetsand the whole car in 2 hours, so that should give you a good indication of how much orange peel there really is.
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21648
02/02/06 11:28 PM
02/02/06 11:28 PM
MNobody Offline
MNobody  Offline
i'm getting too much orange peel too i've tried it thinner, thicker, warmer, colder, can't seem to get it right
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21649
02/02/06 11:33 PM
02/02/06 11:33 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Wicked thread.
Very interesting. I think your onto something.
I prefer the #10 broom finish. That's the only way I can get it to look ,anytime I paint something.
