1969 Road Runner recommended interior paints for M6T trim
#2163070
09/27/16 07:55 PM
09/27/16 07:55 PM
Posts: 17,517 Las Vegas, NV
6bblgt
Las Vegas, NV
I'm returning a '69 Road Runner coupe's bucket seat interior back to the original M6T - it was converted to black years ago. Some of the original tan pieces were dyed/painted black, others were replaced.
it looks like there are 6 different materials or shades of "tan" in the interior:
1) dash frame, upper windshield moulding, column - SUEDE?
2) upper door frame, roof rail, b-pillar - (T7) same as exterior paint?
3) rear window trim, b-pillar trim, door jamb windlace?
4) a-pillar trim, console, bucket seat hinge covers?
5) kick panels?
6) steering wheel? (3-spoke A87 RR)
are the 2 pieces of the interior rear window mouldings available reproduction? where?
which of the above pieces are available reproduction in the correct tan?
Re: 1969 Road Runner recommended interior paints for M6T trim
[Re: 6bblgt]
#2163096
09/27/16 08:39 PM
09/27/16 08:39 PM
Posts: 8,880 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
are the 2 pieces of the interior rear window mouldings available reproduction? where? Can't speak for the upper piece but the lower piece is reproduced and available from Layson's. Its not a perfect repro - wrong plastic and slight difference in the extrusion. But from a couple feet away nobody will ever know. Only in black.
[Re: Stanton]
#2163291
09/28/16 12:17 AM
09/28/16 12:17 AM
Posts: 306 Georgia
69bfan
Georgia
The rear inner window trim is a product manufactured by Trim Parts out of Ohio. A variety of vendors carry the product. You can purchase a complete kit or as stated earlier just the lower piece. We have sold a number of these kits and I would much prefer a good used one, but most of them are so brittle that they will break just trying to remove them. Also as stated, you will have to paint if yours is not black. Also the A-pillars and kick panels are available as repops. I have heard different opinions of the kick panels on the way that they fit. The same goes for the A-pillars, from what I have seen, I would again prefer locating good used and dying them to the correct color for your car.
www.restorationpartsandmaterials.comCorrect Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs. www.dalescudashop.comCorrect style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
[Re: 6bblgt]
#2165196
09/30/16 05:06 PM
09/30/16 05:06 PM
Posts: 20,814 A collage of whims
topside
A collage of whims
The colors varied between the different items somewhat back in the day, easily 4 shades of a given color. I recall that all the package tray moldings at the back glass were black, but the upper ones were in color to match the headliner. DuPont codes for T: Suede - dash, ashtray, glovebox door, w/s center garnish, column: 9624L Laser Gold - C-bodies, apparently 9622L Buckskin Tan - B body Low Gloss - roof rails, A-pillar covers, console, garnish: 9602L Saturn Beige 9605L Desert Tan (light) 9607LH Chestnut Tan (dark) Gloss - door & quarter metal, B-pillar: 4997L Giallo Gold Metallic 4993L Golden Tan Met. (light) 4995LH Teak Tan Metallic This is from a period DuPont chart, and obviously shows more choices than what was used, as they probably included all '69 Plymouth lines except as noted on Suede Unfortunately only the Suede shows a sample color & breakdown.
[Re: 6bblgt]
#2166083
10/01/16 08:06 PM
10/01/16 08:06 PM
Posts: 3,691 MO
cdp
MO
