Re: How much fuel.
[Re: farmboy]
#2162999
09/27/16 06:11 PM
09/27/16 06:11 PM
Posts: 11,729 Portage,michigan
B3422W5
Portage,michigan
Should be roughly twice that.
Re: How much fuel.
[Re: farmboy]
#2163135
09/27/16 09:41 PM
09/27/16 09:41 PM
Posts: 2,686 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
1-1/4 gallons per minute is 75 gallons per hour. That should be enough fuel for 1500 hp. I don't know how strong your car is.
2011 Drag Pak Challenger
Re: How much fuel.
[Re: farmboy]
#2163224
09/27/16 11:10 PM
09/27/16 11:10 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
What tank, pump, lines and reg are you using ?
1963 Plymouth Max Wedge 1971 Barracuda
Re: How much fuel.
[Re: farmboy]
#2163277
09/28/16 12:04 AM
09/28/16 12:04 AM
B3422W5
Portage,michigan
Went back and found a post from on here years ago regards this topic. A 9 sec car should need a gallon every 20 seconds. A 10 sec car a gallon every 25 seconds.
Re: How much fuel.
[Re: B3422W5]
#2163289
09/28/16 12:17 AM
09/28/16 12:17 AM
Thumperdart
State of confusion
Went back and found a post from on here years ago regards this topic. A 9 sec car should need a gallon every 20 seconds. A 10 sec car a gallon every 25 seconds. I use this as a BASIC guide w/accuracy.............
Re: How much fuel.
[Re: DrCharles]
#2163355
09/28/16 01:24 AM
09/28/16 01:24 AM
fast68plymouth
So. Burlington, Vt.
But with the lines disconnected the pump's basically at zero pressure... how much can you pump at operating fuel pressure (6 psi?) That will be less, the question is - how much less Exactly. I don't care what the unrestricted free flow is. I only care what the flow is with the complete system maintaining what I feel is the lowest operating pressure I could live with at the carb(about 5psi).
Re: How much fuel.
[Re: farmboy]
#2164333
09/29/16 01:17 PM
09/29/16 01:17 PM
Thumperdart
State of confusion
Do you have a filter between the cell and pump and if so how many microns............
Re: How much fuel.
[Re: farmboy]
#2164429
09/29/16 03:30 PM
09/29/16 03:30 PM
Posts: 4,704 Wichita
GY3
Wichita
Aluminum fuel cell, Holly 150 pump, 1/2 inch line, and Mallory regulator. Car has made a couple easy 9.90 passes, should do a couple of tenths better. 1/2" line?!
Re: How much fuel.
[Re: farmboy]
#2164529
09/29/16 06:06 PM
09/29/16 06:06 PM
Thumperdart
State of confusion
Hopefully not a flat screen and a sintered filter...........
Re: How much fuel.
[Re: farmboy]
#2164626
09/29/16 08:10 PM
09/29/16 08:10 PM
GY3
Wichita
330, I'm crimping your 5/16 line till you're back in the thirteen's where you belong. LMAO!
Re: How much fuel.
[Re: farmboy]
#2164681
09/29/16 09:11 PM
09/29/16 09:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Yes it is a sintered filter, is that a problem. Not much surface area.. take it out and do your same flow test
Re: How much fuel.
[Re: farmboy]
#2164772
09/29/16 11:14 PM
09/29/16 11:14 PM
ozymaxwedge
Australia
Aluminum fuel cell, Holly 150 pump, 1/2 inch line, and Mallory regulator. Car has made a couple easy 9.90 passes, should do a couple of tenths better. What MPH when running 9.90 ? MPH will be what changes the most with a fuel problem like you have.
