Roller rockers #2162673
09/27/16 11:27 AM
09/27/16 11:27 AM
mass
0
03dodgeram Offline OP
mass
I bought a set of mopar performance roller rockers. I wasn't thinking when bought them but all the boxes are marked ext left and rt. They are the same rockers for ext and intake. Thanks for the help.
Re: Roller rockers [Re: 03dodgeram] #2162788
09/27/16 01:53 PM
09/27/16 01:53 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
What application?
I am a small block guy, but isn't the big-block stuff market left and rt?
Outside of that, are the rockers offset, if so and if they are small-block they may be the W2 rockers, or the earlier T/A stuff, although I didn't think MP every did those.
Re: Roller rockers [Re: 03dodgeram] #2162815
09/27/16 02:40 PM
09/27/16 02:40 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
There should be 8 of one type and 8 of the other (rt and left). There is a difference in the offset as stock rockers have as well. If you look through a service manual etc, and take your time, you will see which way the offset goes when assembled correctly. Keep an eye on pushrods, that they line up. You will see some that get pretty close to intake runner casting. Look it over good before you button it up.
Re: Roller rockers [Re: buildanother] #2162838
09/27/16 03:27 PM
09/27/16 03:27 PM
mass
0
mass
8 left and 8 right.The offset is different. Someone had a set for sale and the ext and int had different part numbers on the boxes. I don't want to buy more if i can use what i already have. Thanks for the help.
Re: Roller rockers [Re: Diplomat360] #2162867
09/27/16 04:00 PM
09/27/16 04:00 PM
mass
0
mass
Big block rockers. 8 left and 8 right. Someone was selling a set of them and hade 4 different part numbers. I'm thinking left and right ext and int are the same. II dont want to buy more if i can use all of these. Paul
Re: Roller rockers [Re: 03dodgeram] #2162974
09/27/16 05:41 PM
09/27/16 05:41 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
On a set of big block heads with stock valve layout the intake rocker for one cylinder will be the same as the exhaust for the cylinder next to it. So in reality, there is no "intake" or "exhaust" or "left" or "right", just two different part numbers.
Re: Roller rockers [Re: Stanton] #2163001
09/27/16 06:14 PM
09/27/16 06:14 PM
mass
0
mass
That what i was thinking. Thanks for the help. Paul
