Ok, need someone to refresh my memory, we are putting the side molding on the Dart, the aluminum with black rubber type. I know you have to put the plastic H shaped clips on the car first, but do you slide the metal clops in the molding and press it onto the plastic clips, or put the metal clips on the car body and slide the molding onto them?
Thanks in advance.
If you didn't build it yourself, it's not really yours - Tim "the toolman" Taylor
