anyone know weight difference in w/p's? #216182
02/06/09 07:42 PM
02/06/09 07:42 PM
KY
juicedcuda Offline OP
KY
I was wondering what the difference would be from a moroso electric w/p on stock housing compared to a meziere/csr electric w/p?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: anyone know weight difference in w/p's? [Re: juicedcuda] #216183
02/06/09 07:44 PM
02/06/09 07:44 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
I dont know for sure but I would say at least 15lbs
Re: anyone know weight difference in w/p's? [Re: juicedcuda] #216184
02/06/09 08:11 PM
02/06/09 08:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
SB or BB?
Re: anyone know weight difference in w/p's? [Re: MR_P_BODY] #216185
02/06/09 08:19 PM
02/06/09 08:19 PM
KY
KY
SB or BB?
oops, sry. big block.
Re: anyone know weight difference in w/p's? [Re: juicedcuda] #216186
02/06/09 08:54 PM
02/06/09 08:54 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The meziere pump for a BB is 7# The aluminum MP WP housing and pump with moroso motor is 14.5#
The stock WP housing and pump weighs 21# add pullys and 1.5# Moroso motor and your looking at 23 to 24#
So your looking at a 15# + minimum difference between a Meziere and a stock steel housing,pump and moroso motor. mike
Re: anyone know weight difference in w/p's? [Re: Sport440] #216187
02/06/09 09:45 PM
02/06/09 09:45 PM
KY
KY
great info! Thanks!
Re: anyone know weight difference in w/p's? [Re: juicedcuda] #216188
02/06/09 11:33 PM
02/06/09 11:33 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
great info! Thanks!
Your Welcome!, I weighed all 3 seperate pump setups on my bathroom scale minutes before I posted. The Meziere being my newest pump upgrade.
The insanity of getting the car lighter never stops. mike
73 Sport 440, 509 cam w/Eddys 3.91 and 28.1"/27.3 tire. Et. 60 ft. 1.435, 1/8th. 6.61 @ 101.80 mph. 1/4. 10.472 / 127.78 mph. 2950# race/with me,and pump gas.
Re: anyone know weight difference in w/p's? [Re: Sport440] #216189
02/07/09 10:46 AM
02/07/09 10:46 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
great info! Thanks!
Not only lighter, in this case you will be faster!
I did the test on an engine dyno with a 615 hp 440. I went from stock wp with crank driven belt to a Moroso electric motor and belt= 19 hp on back to back pulls!
For once the mfg. was accurate on their claim. Don
Re: anyone know weight difference in w/p's? [Re: cudabunch] #216190
02/07/09 12:52 PM
02/07/09 12:52 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I just did this swap,,,
I wanted to put on a different FAN,,,to keep the car cooler,,,
Got a fan from "Eric" here on the board ( he sells them,,and a few members run them )
The FAN is awesome,,,moves a TON of air,,,,
The issue of clearance came up with my old Moroso,,belt driven water pump set up....( which i didnt care for too much anyways ),,,belt from the WP motor ran off the front snout of the water pump
I got a Meizere pump,,,and swapped it in. Fit with no problem,,, MUCH more clearance,,,and the car runs way cooler,,,
I wired the fan and pump on seperate switch's,,,,last fall,,i had to shut the fan OFF,,,cause the car was running too "cool" ( which is a nice problem to have ),,,
There is a weight difference,,,,dont recall how much,,,,
Not sure i saw ANY change is HP going from the Moroso to the Meizere,,,but hard to say,,,,
Doug
Before ( with old Moroso )
After ( with new Meizere pump )
New Fan ( from Eric )
Re: anyone know weight difference in w/p's? [Re: 69CHARGERMD] #216191
02/07/09 08:29 PM
02/07/09 08:29 PM
NC
440Jim Offline
440Jim  Offline
NC
I got a Meizere pump,,,and swapped it in. After ( with new Meizere pump )
I am running that same pump in a MP aluminum housing too. I am happy with it.
Re: anyone know weight difference in w/p's? [Re: 440Jim] #216192
02/07/09 09:42 PM
02/07/09 09:42 PM
KY
KY
I though the meziere pump was a pump/housing combo.
Re: anyone know weight difference in w/p's? [Re: juicedcuda] #216193
02/07/09 09:55 PM
02/07/09 09:55 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
They have both now. The 7# weight I gave was for the Meziere complete pump/housing combo.
I dont know the weight of the Meziere pump only for the stock type housing. But I would Guess it at about 3# to 4#.
I would estimate the total weight the Meziere pump with the MP aluminum housing to still be around the 15# range. mike
