Page 1 of 7 1 2 3 4 5 6 7
engine siezed, any thoughts on why #2160821
09/24/16 01:17 PM
09/24/16 01:17 PM
RapidRobert Offline OP
helped a man with a 340 breakin. fired right up & I held it to 2200-2500. oil psi was 80. water temp climbed to 160 fairly fast. no leaks & sounding good & all of a sudden after about 3-4 minutes it suddenly started to slow down somewhat noticeably & I was manning the throttle & I thought I had with my hand just relaxed/backed off a bit so I moved the throttle up a bit but it stayed the same then 2 seconds later I heard a barely noticeable possibly but not sure metallic "hit" then it died 1 second later. we put a socket on the crank & it is locked solid. No info on clearances. thank you for your time.
Re: engine siezed, any thoughts on why [Re: RapidRobert] #2160831
09/24/16 01:41 PM
09/24/16 01:41 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Possibly a rod bearing piggy backed.
Re: engine siezed, any thoughts on why [Re: killermopar] #2160843
09/24/16 01:52 PM
09/24/16 01:52 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Something I could never comprehend,if you have a crank that is the correct diameter and a rod that has the correct bore and correct bearings with proper clearance,how could one possibly end up on top of the other ?
But,I guess it was thrown together anything is possible ! shruggy
Re: engine siezed, any thoughts on why [Re: RapidRobert] #2160845
09/24/16 01:55 PM
09/24/16 01:55 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
I don't know, but somehow they do. It defies the laws of physics
Re: engine siezed, any thoughts on why [Re: killermopar] #2160858
09/24/16 02:24 PM
09/24/16 02:24 PM
he's a busy guy but he will get back to me when he opens it up. I was not involved in the build but his OCD matches mine (& then some!). he said the shop assured him that P/V collision was not possible with his dimentions (lift/piston amt in the hole). he said the ring gapping was the norm & bearings iirc between 2-3 tho plastigauged. all the final prep we did was standard procedure AFAIK but I feel bad like maybe I missed something. well I guess it is somewhat conjecture for now but I will post how it turns out
Re: engine siezed, any thoughts on why [Re: RapidRobert] #2160879
09/24/16 02:49 PM
09/24/16 02:49 PM
Sounds like some trash got washed into a bearing, maybe a main or rod whiney shruggyLet us know what you find out luck
Re: engine siezed, any thoughts on why [Re: Cab_Burge] #2160881
09/24/16 02:53 PM
09/24/16 02:53 PM
I definitely will Cab
Re: engine siezed, any thoughts on why [Re: RapidRobert] #2160903
09/24/16 03:33 PM
09/24/16 03:33 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Hmmmm.
I would not consider someone OCD if he relies on the shop for PV clearances and his use of plastigauge for checking bearing clearances........
Re: engine siezed, any thoughts on why [Re: RapidRobert] #2160915
09/24/16 03:46 PM
09/24/16 03:46 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
What was the temp and oil pressure when it "slowed down"?
Re: engine siezed, any thoughts on why [Re: Morty426] #2160968
09/24/16 05:30 PM
09/24/16 05:30 PM
BSB67, point taken. Morty, same no waver which you would expect on the water temp. it happened FAST, out of the clear blue/no warning, with one or two seconds total from first hiccup to dieing & closer to less than 1 second
Re: engine siezed, any thoughts on why [Re: RapidRobert] #2161017
09/24/16 08:03 PM
09/24/16 08:03 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
We're any of these sand or bead blasted?
Intake manifold
Valve covers
Oil pan
Timing cover
I ask because I've seen this done on many occasions, and when the post blasting cleaning procedure isn't 100%, you often end up with a situation like what was described.
Re: engine siezed, any thoughts on why [Re: fast68plymouth] #2161033
09/24/16 08:26 PM
09/24/16 08:26 PM
I will add that to my list of questions
Re: engine siezed, any thoughts on why [Re: fast68plymouth] #2161048
09/24/16 09:18 PM
09/24/16 09:18 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Intake manifold
Valve covers
Oil pan
Timing cover
iagree
The only thing I glass bead blast in a engine is iron rods and crank to be able to check for cracks and that's it.
Definitely never aluminum anything, especially not a intake manifold.
I learned this on my own the hard way when I was about 19-20 years old and did my own 340 rebuild and used my bosses bead blaster cabinet.
Now I use a steam pressure washer to prep my rebuilds.
Sounds like it spun a bearing... frown
Re: engine siezed, any thoughts on why [Re: Challenger 1] #2161055
09/24/16 09:22 PM
09/24/16 09:22 PM
it's gonna be interesting what it ends up being
Re: engine siezed, any thoughts on why [Re: RapidRobert] #2161197
09/25/16 03:13 AM
09/25/16 03:13 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Main bearing clearance too tight. Possible rod, but I like main. You did not suggest hearing knock as engine slowly slowed down. Just sayin.
Re: engine siezed, any thoughts on why [Re: Sxrxrnr] #2161201
09/25/16 03:29 AM
09/25/16 03:29 AM
I heard a very slight what sounded like a metallic contact of some sort & it starting to slow down (both at the same time) & I looked over at the tach cuz I thought I had let up on the throttle & I started to throttle it back up & it died. all this took place in about 2 seconds from start to finish & I was thinking later I shoulda killed it on that first contact however slight I heard but it died in about the time it would have taken me to reach the kill switch cuz I was not sure where exactly the switch was (he fired it up/I twisted the dist/pointed the light/kept the throttle open/checked for leaks). EDIT SXR I reread your post & there was the one slight contact rather than a continual interference (if that helps)
Re: engine siezed, any thoughts on why [Re: RapidRobert] #2161218
09/25/16 04:49 AM
09/25/16 04:49 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
A friend of mine had somebody else build a 440 for him a number of years ago. They put the wrong bearing shells in the block (no oil holes)...I think his wife was about 20 miles from home when the motor seized...\
Re: engine siezed, any thoughts on why [Re: RapidRobert] #2161260
09/25/16 10:50 AM
09/25/16 10:50 AM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
how tight was piston to cylinder wall clearance?? the time frame would be about right for the pistons to seize in the cylinders if the clearance was too tight..
Re: engine siezed, any thoughts on why [Re: rumblebee4232] #2161265
09/25/16 10:58 AM
09/25/16 10:58 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
One can surmise all day long but the correct answer will come when you take it apart! no
Re: engine siezed, any thoughts on why [Re: 62maxwgn] #2161275
09/25/16 11:33 AM
09/25/16 11:33 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Once the engine cooled to ambient, is it still locked up? My thought would be insufficient piston/wall clearance. I've been involved in a case with a tight bearing. The bearing wiped but didn't lock the engine up.
