Page 7 of 85 1 2 5 6 7 8 9 84 85
Re: paint job on a budget!? [Re: 69superbee383] #21610
01/27/06 07:52 PM
01/27/06 07:52 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I guess getting a specific color mixed could be a PITA though, seeing as you'd pretty much have to bring in a paint chip for them scan in the computer.
Re: paint job on a budget!? [Re: DaytonaTurbo] #21611
01/27/06 08:20 PM
01/27/06 08:20 PM
Bellevue, WA
Blackwidow69 Offline
Ring Knocker
Ring Knocker
Bellevue, WA
I am a little surprised that so many of you guys have not read about this before here on Moparts. Primerduster has been talking about it for at least a few years. And I rolled on rustoleum last fall and posted the results. But I have to say the info here is much more detailed and I guess we were only talking about using the flat black paint to make our cars look like primered rides.
I got to say 69charger is doing a great job passing the info and staying out of any arguments so kudos for that. I will just say keep trying on getting the thinner to paint mixture down. It really does help to get it quite thin but like 69charger I cannot give you a specific ratio. My trunk lid probably has like 10 coats of paint on it from experimentation and I did just use the grey spray primer in the areas that I took down to metal for smoothing out purposes. My car does look mean and at the Mopar show here in Maryland last fall everyone did think it was sprayed on epoxy primer. Their faces were priceless when I told them it was rolled. Anyway nothing really new to add since 69charger has done a good job so just count me in as a satisfied $50 paint job guy.
Todd
1969 Ply Roadrunner, 383 4-speed on street tires. 3,830 lbs race weight. Best 1/4: 13.1 @ 106.83 440 & overdrive 4 speed going in. 2005 Power Wagon 35X12.5 KM2's
Re: paint job on a budget!? [Re: Blackwidow69] #21612
01/27/06 08:25 PM
01/27/06 08:25 PM
Manitoba, Canada
Manitoba, Canada
I don't think it really matters exactly how much thinner is used, but it does matter how thin the end product comes out. If it's warmer outside, obviously the warm paint will be not so thick and won't require as much thinner to achieve the proper thickness. It's really based on ambient temperature so you can't just lay down a specific mix.
Re: paint job on a budget!? [Re: 73cudaproject] #21613
01/27/06 08:45 PM
01/27/06 08:45 PM
Columbus Ga
reflections7 Offline
Columbus Ga
I called a paint supply store and asked about roll-on primer. I was told any epoxy primer, 2K primer, etc. can be rolled on. He did not mention what reducer to use. Any advice? My current application is just on a beater type truck but I want fairly good results. The metal is currently bare and I want to prime before I use body filler. The link provided earlier indicates the primer needs to be a direct to metal type.
I didnt get good results unless I used primer made to roll.
Re: paint job on a budget!? [Re: reflections7] #21614
01/28/06 01:27 PM
01/28/06 01:27 PM
MNobody Offline
MNobody  Offline
guess i'll have to hire YEEHAA to come to michigan and paint mine i don't have the knack for it....
Re: paint job on a budget!? [Re: MNobody] #21615
01/28/06 03:30 PM
01/28/06 03:30 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
Well I've got an old fender I'm going to try this on. I know I'm suposed to wet sand after the second coat, but how much time is needed between coats?
Mike
Re: paint job on a budget!? [Re: reflections7] #21616
01/28/06 03:40 PM
01/28/06 03:40 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I tried rolling DP90. Doesn't work-dries too fast. -Bob
Re: paint job on a budget!? [Re: BobR] #21617
01/28/06 03:59 PM
01/28/06 03:59 PM
MNobody Offline
MNobody  Offline
make sure you wet sand after each coat and mine dried overnight.
Re: paint job on a budget!? [Re: MNobody] #21618
01/28/06 09:03 PM
01/28/06 09:03 PM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
Well i did two coats Firday night and then this afternoon wet sanded with 400 and after that applied another coat. Things looked good at first but the paint dried in a finish similar to the crinkle finish on an air cleaner...me thinks me did something wrong. It did seem to have potential though and I am going to keep playing with it.
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: paint job on a budget!? [Re: 69superbee383] #21619
01/29/06 12:52 AM
01/29/06 12:52 AM
MNobody Offline
MNobody  Offline
yeah i got one section of the hood i'm doing that wrinkled too i think the hood was too cold when i applied the paint. and hey i tried my palm sander... keep it good and wet it works great.
Re: paint job on a budget!? [Re: MNobody] #21620
01/29/06 12:54 AM
01/29/06 12:54 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
Hey what was your guy's mixing ratio?
Mike
1969 Dodge Dart Swinger
Re: paint job on a budget!? [Re: MikeyT] #21621
01/29/06 04:44 PM
01/29/06 04:44 PM
toronto canada
69chargeryeehaa Offline
toronto canada
there is no real set mixing ratio, it's all based on the temperature, how old the paint is, how many times you opened the can, and which way the wind is blowing!!! you just have to have a "feel" for it. i've painted in both extreems of temperature, from about -10 deg celcus to +30 deg celcus and never had a problem with the paint having any bad habbits, but the mixing ratio was higher the colder it was.
Re: paint job on a budget!? [Re: 73cudaproject] #21622
01/30/06 12:34 AM
01/30/06 12:34 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21623
01/30/06 12:50 AM
01/30/06 12:50 AM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
This thread ROCKS!
I need to get my plow truck painted within the next year or so, and this sounds like JUST what I'm looking for!!!
Thanks!
Re: paint job on a budget!? [Re: 440trk] #21624
01/30/06 12:56 AM
01/30/06 12:56 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Anyone else experiment with this over the weekend? I've put on 2 coats on a test area of an old door, wetsanding is next. Hard to tell what the finished product will look like at this point, and I'm getting some dog hair and other misc. junk on my test area, I need to take care of that..
Re: paint job on a budget!? [Re: Exit1965] #21625
01/30/06 02:37 AM
01/30/06 02:37 AM
AK plates roaming in South TX!...
phoenix70charger Offline
I like this idea!! Gotta move to a new base before I can try it though
Re: paint job on a budget!? [Re: phoenix70charger] #21626
01/30/06 04:57 AM
01/30/06 04:57 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
so how do you apply the paint in hard to reach areas? such as drip rails on the roof edge--the vent slots in front of the widshield, etc.. ?
Re: paint job on a budget!? [Re: 493_DART] #21627
01/30/06 11:02 AM
01/30/06 11:02 AM
toronto canada
toronto canada
for the vent slots for example i would use the foam brush and run it in between the slots, then use the roller over it, when done u can't even tell it was not sprayed. and same thing for the drip rail, use the foam brush first, then use the rounded end of the roller pushing it into the drip rail and then turning it and using the straight cut end to perfect it.
Re: paint job on a budget!? [Re: 69chargeryeehaa] #21628
01/30/06 01:05 PM
01/30/06 01:05 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
this morning I wet sanded the first 2 coats with 600 grit. It's smooth now but it doesn't yet have full color covering the area. Tonight I'll do 2 more coats then wetsand tomorrow morning with 800.
We'll know how it turns out in a couple of days, but so far about 10-15% mineral spirits is what has worked for me. It goes on very easily, and doesn't run. Wetsanding was pretty easy too.
Re: paint job on a budget!? [Re: Exit1965] #21629
01/30/06 01:30 PM
01/30/06 01:30 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
So you guys are using mineral sprits?
When I sprayed rustolem last summer, I thought it said to thin it with asatone (sp?)...
Is it different if you roll it vs. spraying? Or is mineral sprits better for this process?
Or am I just
RAR II
