5.7 Hemi plug change time #2155271
09/15/16 07:19 PM
09/15/16 07:19 PM
Kentucky
dfsmopars Offline OP
Kentucky
30,000 miles now on my '14 Ram and time to change plugs. Do Moparts members just put a single copper plug in each hole for $2-$3 and forget it until the next 30,000?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: 5.7 Hemi plug change time [Re: dfsmopars] #2155278
09/15/16 07:44 PM
09/15/16 07:44 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why change them so early? I changed mine at 75,000 and they still looked like new. It now has 160,000 and has had 2 plug changes. I did replace all 16 of them each time. Champion 7570 (RE14PMPB).
Re: 5.7 Hemi plug change time [Re: dfsmopars] #2155413
09/15/16 11:36 PM
09/15/16 11:36 PM
Kentucky
Kentucky
Just going by the manual.
Re: 5.7 Hemi plug change time [Re: dfsmopars] #2155474
09/16/16 01:02 AM
09/16/16 01:02 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
"single copper plug in each hole for $2-$3 and forget it until the next 30,000"
That's what I'd do,not a hard job just boring after the 11th plug lol.
Mopar or Champion only.
Re: 5.7 Hemi plug change time [Re: dfsmopars] #2155749
09/16/16 02:40 PM
09/16/16 02:40 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My kids 04 we did at about 28K.He used Champion double platinums.His buddy works there so they were free.At about 80K changed them and the wires.Has over 110 now and still going good.Use a dab of antisieze on the threads and some diaelectric grease on the boots.Makes removing then next time easy.Rocky
Chrysler Firepower
Re: 5.7 Hemi plug change time [Re: stumpy] #2155770
09/16/16 03:04 PM
09/16/16 03:04 PM
Kentucky
Kentucky
OK there is confusion on my part. In 2014 looks like the recommended interval changed to 100,000. I'll just keep my $32 and wait. So it does appear the prior 30,000 mile recommendation was an overkill. I had a warranty call and the dealership quoted $540 for the plug swap and told me the plugs were due at 30,000. frown
Re: 5.7 Hemi plug change time [Re: dfsmopars] #2157250
09/19/16 10:05 AM
09/19/16 10:05 AM
,Pa.
68dodge Offline
68dodge  Offline
,Pa.
I change mine first time on a 2010 power wagon at 28000 and the gap on the spark plugs was at .070. Ever since that I check them every 25000. I can not see going that long on a spark plug.
Re: 5.7 Hemi plug change time [Re: 68dodge] #2158874
09/21/16 05:35 PM
09/21/16 05:35 PM
dogdays Offline
dogdays  Offline
I had a post that disappeared.
I've run double platinum a minimum of 75,000 miles in three different vehicles and none of them was missing when I removed the plugs. One of them did have a pretty big gap, like 0.060, but it was still firing. OBDII will let you know if there's a misfiring plug.
My last set of plugs was DensoTT. This is the leading edge in spark plugs, as far as I can tell. I only had to buy four. The original double platinum Champions were at 115,000 miles and were pretty well worn out.
For your truck it's the Denso 4703 at $5.53 each or the Autolite XP5325 at 4.45 each with a $2.50 rebate per plug. That calculates out to a little more than $2.00 per plug with shipping. It's pretty hard to resist.
AUTOLITE XP5325 {#XP5325DP2} Iridium; 14mm Thread Diameter (Rebate/Promotion Available!) Sale! Info
.045 Gap; OE Style; Requires 2 plugs per cylinder
Choose: ($4.45) {1}+
R.
Re: 5.7 Hemi plug change time [Re: dogdays] #2158918
09/21/16 06:37 PM
09/21/16 06:37 PM
Kentucky
Kentucky
R.
Thanks for that!
Re: 5.7 Hemi plug change time [Re: dfsmopars] #2160565
09/24/16 12:12 AM
09/24/16 12:12 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I've changed the plugs in mine 5 or 6 times in 280,000 miles and still have not improved on my times. 16 plugs with half of them under the windshield, brake booster, etc !!!
Re: 5.7 Hemi plug change time [Re: Kern Dog] #2160709
09/24/16 10:20 AM
09/24/16 10:20 AM
IN
ahy Offline
ahy  Offline
IN
I know the earlier hemi's had the 30k plugs and later 100k I think. The owners manual does not seem to have kept up somehow.
I have changed them quite a few times... not a bad job but takes some time and patience. I like to give the coil connectors a little shot of WD40 before removing. They unlock and slip off easier. As mentioned, a little anti-seize on the threads when they go back in.
Re: 5.7 Hemi plug change time [Re: dfsmopars] #2160901
09/24/16 03:22 PM
09/24/16 03:22 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My 08 Ram had the original plugs in when I got it at 72,000 miles. The plugs looked fine, and I saw no MPG or other improvements by changing them.
Its possible the plugs had been changed but the truck came with records for everything done to it since 12K miles and there was no plug service in the list.
68 Barracuda Formula S 340
Re: 5.7 Hemi plug change time [Re: dfsmopars] #2161198
09/25/16 03:20 AM
09/25/16 03:20 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
2014 has NGK dbl platinum plugs.Thats the reason for the 100,000 mile changes.No reason to use the older champs.
Leave the gun.......take the Cannoli's....Mike
Re: 5.7 Hemi plug change time [Re: dfsmopars] #2163725
09/28/16 03:58 PM
09/28/16 03:58 PM
crabman173
crabman173
I have an 08 says every 30K or so--first ones replaced at 55k Best deal is get them off ebay way cheaper than anywhere else--stay with the factory Champions --the deal is if you don't change them often enough you can have trouble getting them out if you go way overboard--slather them up good with anti seize so in the future they come on out
I went about 50K on last set and gap had opened up--also helps you keep an eye on things inside Unlike other vehicles I can't say it felt one bit different and MPG is what it always is--
Re: 5.7 Hemi plug change time [Re: dfsmopars] #2163910
09/28/16 09:25 PM
09/28/16 09:25 PM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
I'm lazy, my o7 has 150 on the factory plugs. I need to sway in a new set, then good for another 150.
