If original BS was on 8"by 11"sheet,all that's left is bottom 5".I am gonna post build codes in hopes Youse Guys can tell Me what they all mean,and I have questions about some stuff...dist 44,sway bar 0,rad 65,engine 389,trans 542,axle 618,pinion 29,clutch/brake brkt 35,frnt brk 22,shocks 67f,41r,batt 59,stub frame 15,carb34..
And the questions:I am 2nd owner of Car,'67 GTX
conv.,440 4bbl,auto,and I'm the one doing all resto work,and I personally dismantled Car,made tons of notes,took pix.So We know this Car should of had 781/780 bars,but build sheet says 777/776 ?
What's confusing is,donor Belvedere from South I
dismantled for OEM chassis parts didn't have torque boxes,but had 780/781 bars-wassup wid dat??
Here's rest of questions:Box 62 on BS,h.d.batt has a 2 in it,box 564 has a 4,bx 535 look like a 5,box 52 tinted/clear glass has a 2,box 514 has a
4,and last-box 517,turn ind fndr mntd has a 7. Can
Youall help??And in rear springs,code says 005/005-does that mean equal 5 leaf springs??Strange,bcuz springs i took out of Car had more
leaves on right than left-please Help!!
