SB Victors with Crower stainless rockers.
#2160216
09/23/16 04:24 PM
09/23/16 04:24 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: SB Victors with Crower stainless rockers.
[Re: CJD AUTOMOTIVE]
#2160226
09/23/16 04:30 PM
09/23/16 04:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats a nice looking set up... is that on a 59* block and was there any clearance work needed for the push rods.. also whats the rocker ratio.. thanks
#2160238
09/23/16 04:48 PM
09/23/16 04:48 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I just saw a thing on facebook about this. They said any ratio because they use an existing rocker arm design, the shafts must be the special part. That is good because it should help keep the cost down and be less "special".
68 Barracuda Formula S 340
#2160254
09/23/16 05:18 PM
09/23/16 05:18 PM
Porter67
[Re: Bad340fish]
#2160272
09/23/16 05:57 PM
09/23/16 05:57 PM
Posts: 760 Canada
CTD5.9
Canada
I just saw a thing on facebook about this. They said any ratio because they use an existing rocker arm design, the shafts must be the special part. That is good because it should help keep the cost down and be less "special". Looks like the heads will also have a special Edelbrock part number and come with the stands milled off and extra holes tapped. I would assume a good machinist can do the same process though.
[Re: MR_P_BODY]
#2160478
09/23/16 10:28 PM
09/23/16 10:28 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Thats a nice looking set up... is that on a 59* block and was there any clearance work needed for the push rods.. also whats the rocker ratio.. thanks Looks like a 59* block in the pictures
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: slammedR/T]
#2160485
09/23/16 10:33 PM
09/23/16 10:33 PM
MR_P_BODY
Thats a nice looking set up... is that on a 59* block and was there any clearance work needed for the push rods.. also whats the rocker ratio.. thanks Looks like a 59* block in the pictures Yeah I see the lifters but just verifying and wanted to know about the PR clearances
[Re: MR_P_BODY]
#2160498
09/23/16 10:52 PM
09/23/16 10:52 PM
slammedR/T
Thats a nice looking set up... is that on a 59* block and was there any clearance work needed for the push rods.. also whats the rocker ratio.. thanks Looks like a 59* block in the pictures Yeah I see the lifters but just verifying and wanted to know about the PR clearances I'm curious on the PR clearance also, my indy 360-1 heads on my stock 59* block didn't have enough room for a 3/8 intake pushrod even with my MRL offset lifters.
#2160538
09/23/16 11:45 PM
09/23/16 11:45 PM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Great photos, Craig. After seeing this, now I'd like to see what the Hughes "fully assembled" version looks like for comparison.
Mo' Farts
Moderated by "tbagger".
[Re: MR_P_BODY]
#2160727
09/24/16 11:09 AM
09/24/16 11:09 AM
Posts: 656 Florida
CJD AUTOMOTIVE
Thats a nice looking set up... is that on a 59* block and was there any clearance work needed for the push rods.. also whats the rocker ratio.. thanks Yep, 59 360 block. Don didn't mention any clearance work needed for pushrods, but I'll ask.
[Re: AndyF]
#2160729
09/24/16 11:10 AM
09/24/16 11:10 AM
Posts: 656 Florida
CJD AUTOMOTIVE
Looks nice. Those look like cast rocker arms, very cool stuff. Yep, investment cast stainless.
#2160764
09/24/16 11:56 AM
09/24/16 11:56 AM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Any idea on price point for those rockers?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2160907
09/24/16 03:39 PM
09/24/16 03:39 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Any idea on price point for those rockers? Not yet. I had Edelbrock take my heads over to Crower to have these made....that was 7 months ago. Not bitching too much, because I'm finally getting them. Figuring a little more than Jesel or T&D aluminum shafts, but way less than either of those companies stainless versions. We'll see.
#2171363
10/10/16 10:25 AM
10/10/16 10:25 AM
Posts: 656 Florida
CJD AUTOMOTIVE
Got answers. Mockup is using a 3/8" pushrod. No clearance issues according to Don at Crower. He is using a .350 offset intake and .100 offset exhaust.
