jack base stamping ? #216003
02/06/09 01:50 PM
02/06/09 01:50 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
I've got a like new jack base with a stamp of U69 i'm guessing 1969 what does the u mean (week)? how do you date the base/jack/ hook ect.
Re: jack base stamping ? [Re: ademon] #216004
02/06/09 03:49 PM
02/06/09 03:49 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Dec 69
A = Jan
M = Dec
I = Not used
Re: jack base stamping ? [Re: ademon] #216005
02/06/09 03:55 PM
02/06/09 03:55 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Well without seeing a picture of the base I think you could be the proud owner of a Chevy Base. Dont take my work on it do an Ebay search for Chevy Jacks or Camaro Jacks and see it something comes up that looks identical.
1971 HEMI E BODY REGISTRY
Re: jack base stamping ? [Re: hemicar1971] #216006
02/06/09 04:30 PM
02/06/09 04:30 PM
Snoopy Offline
Snoopy  Offline
Here are a couple of pictures of jack bases.
Solid T-Mast
Re: jack base stamping ? [Re: Snoopy] #216007
02/06/09 04:31 PM
02/06/09 04:31 PM
Snoopy Offline
Snoopy  Offline
Tube Type Mast
Re: jack base stamping ? [Re: Snoopy] #216008
02/06/09 07:07 PM
02/06/09 07:07 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
All U69 Jack Bases on E Bay at the present time are for 1969 Camaros. Item Number 120371723100 is one example.
Snoopy your post with the T Type Jack Base I believe is for a 70 or 71 E Body with a T Type Mask.I am thinking that your U70 Base might be for a 1970 GM. I have a U69 Jack base and it goes with the 1969 Camaro Jack Assy I have.
Re: jack base stamping ? [Re: hemicar1971] #216009
02/06/09 07:22 PM
02/06/09 07:22 PM
Snoopy Offline
Snoopy  Offline
The one on the left is Mopar, the one on the right may be GM. Both are U70.
Re: jack base stamping ? [Re: Snoopy] #216010
02/07/09 04:03 AM
02/07/09 04:03 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Well heres the U69 base, looks different than ones on e-bay got a notch on the side, probably for Yenkos, .
Re: jack base stamping ? [Re: ademon] #216011
02/07/09 04:06 AM
02/07/09 04:06 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
The jack in my 71 demon is stamped 2K my rear bumper has notches? shaft does not fit into base,hole in base is bigger so my jack is not safe to use, so i'm guessing i need a base with A,B,C 71 to be correct for my 4/71 built demon.
